I’m completely new in Nvidia products. I would like to use Rivermax SDK to get an HDMI 1080P stream and convert it to the Network stream with pre-processing. Pre-processing will be based on JSON scenarios loaded from the user space wich will affect each pixel from the video stream.
Is it possible to get this using rivermax? And, Do I need to write a special code for the DPU processor?
Many thanks
UPD,
Hardware with RDMA support
NVIDIA Mellanox MCX623106AN-CDAT ConnectX®-6 Dx EN Network Interface Card
Thank you for your reply. So no any chance to create DPU routine or such for making pixel processing and create own SDP profile for sending in your own format using RDMA and NIC?
