Hi there,
I installed RTAudio on Jetson Nano. When trying the provided samples, I always hear some noise in the earphones (The USB gaming headset is connected to Jetson Nano through the USB port). I tried RTAudio on Windows and it is working fine. I tried different sampling rates but it did not work and I do not know where the noise is coming from. The Jetson nano should be powerful enough to simultaneously record audio recording and play. Any suggestions?
Thank you in advance for any help.
Best,
Larry
