This is what I mixed up
#!/usr/bin/env python
import copy
import os
import omni
import numpy as np
from omni.isaac.python_app import OmniKitHelper
from pathlib import Path
import matplotlib.pyplot as plt
import logging
import asyncio
SEED = 1337
EXAMPLE = Path(__file__).parent.parent / Path("./data/raw/shipsShaded.usda")
def setup_logging(level=logging.INFO):
logging.basicConfig(level=level)
urllib3_logger = logging.getLogger("urllib3")
urllib3_logger.setLevel(logging.INFO)
setup_logging()
async def load_stage(path):
await omni.usd.get_context().open_stage_async(path)
def _setup_world(kit, scenario_path):
# Load scenario
setup_task = asyncio.ensure_future(load_stage(scenario_path))
while not setup_task.done():
# logging.info("Update in progress")
kit.update()
kit.setup_renderer()
kit.update()
logging.info(f"Stage opened with {scenario_path}")
np.random.seed(SEED)
def main(
usd_file=f"{EXAMPLE.absolute()}",
camera_name="/Camera/Camera_001",
width=1920,
hieght=1080,
start_frame=0,
end_frame=120,
background_match="Plane",
output_path="./data/output/ground_truth_examples/example1.####.png",
output_folder = Path(output_path).parent
output_folder.mkdir(parents=True, exist_ok=True)
logging.info("Start up")
kit = OmniKitHelper(
"renderer": "PathTracedLighting",
"experience": f'{os.environ["EXP_PATH"]}/omni.isaac.sim.python.kit',
"width": width,
"height": hieght,
logging.info("Start End")
from pxr import Semantics # Note: Import after kit is instantiated
from omni.syntheticdata import visualize, helpers # Note: as above
from omni.isaac.synthetic_utils import (
SyntheticDataHelper,
) # Note: as above
sd_helper = SyntheticDataHelper()
logging.info("Imports End")
_setup_world(kit=kit, scenario_path=usd_file)
kit.update()
stage = kit.get_stage()
logging.info("Open Stage End")
for prim in stage.Traverse():
if prim.GetTypeName() == "Mesh":
prim.GetAttribute("primvars:displayColor").Set([np.random.rand(3).tolist()])
sem = Semantics.SemanticsAPI.Apply(prim, "Semantics")
sem.CreateSemanticTypeAttr()
sem.CreateSemanticDataAttr()
sem.GetSemanticTypeAttr().Set("class")
prim_type = prim.GetTypeName()
if str(prim_type) == "Mesh":
if background_match in str(prim.GetPath()):
sem.GetSemanticDataAttr().Set("background")
logging.info(f"Background Mesh: {prim.GetPath()}")
else:
sem.GetSemanticDataAttr().Set("foreground")
logging.info(f"Foreground Mesh: {prim.GetPath()}")
logging.info("Traverse Stage End")
kit.update()
logging.info("Update End")
viewport = omni.kit.viewport.get_default_viewport_window()
logging.info("Viewport End")
viewport.set_active_camera(camera_name)
timeline = omni.timeline.get_timeline_interface()
for i in range(1000):
kit.update()
for cur_frame in range(start_frame + 1, end_frame + 1, 1):
timeline.set_current_time(cur_frame)
for i in range(20):
kit.update()
gt = sd_helper.get_groundtruth(
"rgb",
"depth",
"boundingBox2DTight",
"boundingBox2DLoose",
"instanceSegmentation",
"semanticSegmentation",
"boundingBox3D",
"camera",
viewport,
# GROUNDTRUTH VISUALIZATION
# Setup a figure
_, axes = plt.subplots(2, 4, figsize=(20, 7))
axes = axes.flat
for ax in axes:
ax.axis("off")
# RGB
axes[0].set_title("RGB")
for ax in axes[:-1]:
ax.imshow(gt["rgb"])
# DEPTH
axes[1].set_title("Depth")
depth_data = np.clip(gt["depth"], 0, 255)
axes[1].imshow(visualize.colorize_depth(depth_data.squeeze()))
# BBOX2D TIGHT
axes[2].set_title("BBox 2D Tight")
rgb_data = copy.deepcopy(gt["rgb"])
axes[2].imshow(visualize.colorize_bboxes(gt["boundingBox2DTight"], rgb_data))
# BBOX2D LOOSE
axes[3].set_title("BBox 2D Loose")
axes[3].imshow(visualize.colorize_bboxes(gt["boundingBox2DLoose"], rgb_data))
# INSTANCE SEGMENTATION
axes[4].set_title("Instance Segmentation")
instance_seg = gt["instanceSegmentation"][0]
instance_rgb = visualize.colorize_segmentation(instance_seg)
axes[4].imshow(instance_rgb, alpha=0.7)
# SEMANTIC SEGMENTATION
axes[5].set_title("Semantic Segmentation")
semantic_seg = gt["semanticSegmentation"]
semantic_rgb = visualize.colorize_segmentation(semantic_seg)
axes[5].imshow(semantic_rgb, alpha=0.7)
# BBOX 3D
axes[6].set_title("BBox 3D")
bbox_3d_data = gt["boundingBox3D"]
bboxes_3d_corners = bbox_3d_data["corners"]
projected_corners = helpers.world_to_image(
bboxes_3d_corners.reshape(-1, 3), viewport
projected_corners = projected_corners.reshape(-1, 8, 3)
bboxes3D_rgb = visualize.colorize_bboxes_3d(projected_corners, rgb_data)
axes[6].imshow(bboxes3D_rgb)
# Save figure
plt.savefig(
f"{output_folder}"
+ f'/{Path(output_path).name.split(".")[0]}.'
+ f'{cur_frame:04d}.{Path(output_path).name.split(".")[-1]}'
plt.close()
logging.info(f"Frame {cur_frame:04d} Done!")
# cleanup
kit.shutdown()
if __name__ == "__main__":
main()
