Hi all, I’m writing a Kernel that performs image dilation. I’m trying to use shared memory, but it’s giving me bad results.
Particularly, it returns all zeros, which should not be happening.
To debug, I tried loading each matrix I’m working with into arrays in the shared memory, then load these shared memory arrays directly to the output matrix. Sometimes this gives the correct output, not sometimes not.
I’ve included this in the comments in my code.
Can you guys help identify the problem? I have no idea what is causing this.
Thanks in advance!!
cudaMemset(result.d_arrayPtr,0,result.width*result.height*sizeof(*result.d_arrayPtr)); //set the output array to 0 in host code
extern __shared__ int sArray[]; //declare shared memory array dynamically
__global__ void dilateOnGPU(matrix *dest, matrix *image, matrix *kernel){
int down, across, value, maxv, h, w, resultIndex, sampleIndex, kernelIndex, sSubIndex, a_rowOffset, b_rowOffset;
int* sSub = (int*)&sArray; //shared memory array for sub-sample
int* sKernel = (int*)&sArray[256*4]; //shared memory array for kernel
h=blockIdx.y * blockDim.y + threadIdx.y;
w=blockIdx.x * blockDim.x + threadIdx.x;
resultIndex = w+h*dest->width; //for the grid
sampleIndex = w+h*image->width; //for the grid
sSubIndex = threadIdx.x+threadIdx.y*blockDim.x; //for every block
kernelIndex = threadIdx.x+threadIdx.y*kernel->width; //for every block
dest->d_arrayPtr[resultIndex]=0; //store result here
maxv = 0;
//place a submatrix of image into each block's shared memory
sSub[sSubIndex] = image->matrixGPUelement(sampleIndex);
dest->d_arrayPtr[resultIndex]= sSub[sSubIndex]; //I tried just setting the sSub as the output, and see if the program displays the image; it does.
//place kernel in shared memory
//one kernel in every block, all kernels fit in block
if(threadIdx.y < kernel->width && threadIdx.x < kernel->width)
sKernel[kernelIndex] = kernel->matrixGPUelement(kernelIndex);
dest->d_arrayPtr[resultIndex]= sKernel[kernelIndex]; //I tried just setting the sKernel as the output, and see if the program displays a kernel in every block, and it does
dest->d_arrayPtr[resultIndex]= sKernel[kernelIndex]; //however, if I call this line twice, the out displays all zeros!
//perform dilation in each block. This doesn't work either; I'm getting all zeros in my output.
//each thread in each block will perform:
if(threadIdx.x < blockDim.x-kernel->width+1 && threadIdx.y < blockDim.y-kernel->width+1){ //problem with padding
for(down=0;down<kernel->height;down++){ //multiplies each colum
a_rowOffset = down*blockDim.x;
b_rowOffset = down*kernel->width;
for(across=0;across<kernel->width;across++){ //multiplies each row
value = sKernel[b_rowOffset+across] * sSub[sSubIndex + a_rowOffset+across];
if(value>maxv) maxv = value;
dest->d_arrayPtr[resultIndex]=maxv; //the out displays all zeros, which is wrong.
