Using shared memory in device function and allocate required shared memory in global function
Normally I’m using new/delete to allocate memory heap in device code for some variables but it’s too slow and after looking this blog; Using Shared Memory in CUDA C/C++ | NVIDIA Technical Blog I saw that shared memory could be 100x faster and also Fermi (microarchitecture) - Wikipedia says shared memory at L1 cache needs 10-20 cycles to access and global memory needs 600 - 800 cycles to be accessed. So I think the main reason for it takes that much time is using heap memory with new/delete
Currantly I’m using
__device__ void GetNetworkOutput(float* rollingdata, Network* net, int* output_ids, uint8_t* result_id) {
    float* outputs = new float[net->num_neurons];
    float* values = new float[net->num_neurons];
    bool* completed = new bool[net->num_connections];
    if (outputs == nullptr || values == nullptr || completed == nullptr) {
        printf("Memory allocation failed\n");
        return;
    for (int i = 0; i < net->num_neurons; ++i) {
        if (net->Neurons[i].type == 0) {
            values[i] = rollingdata[i];
            outputs[i] = rollingdata[i];
        else {
            values[i] = 0.0f;
            outputs[i] = 0.0f;
    bool finished = false;
    for (int i = 0; i < net->num_connections; ++i) {
        if (net->Neurons[net->Connections[i].from].type == 0) {
            values[net->Connections[i].to] += net->Connections[i].weight * values[net->Connections[i].from];
            completed[i] = true;
        else {
            completed[i] = false;
    while (!finished) {
        finished = true;
            if (!completed[i]) {
                finished = false;
                if (values[net->Connections[i].from] != 0.0f) {
                    bool ehezowski = true;
                    for (int j = 0; j < net->Neurons[net->Connections[i].from].connected_num; ++j) {
                        if (outputs[net->Neurons[net->Connections[i].from].incoming_connections[j]] == 0.0f) {
                            ehezowski = false;
                    if (ehezowski) {
                        if (outputs[net->Connections[i].from] == 0.0f) {
                            outputs[net->Connections[i].from] = activationFunction(values[net->Connections[i].from] + net->Neurons[net->Connections[i].from].bias);
        if (net->Neurons[i].type == 2) {
            outputs[i] = activationFunction(values[i] + net->Neurons[i].bias);
    float biggest = -1500.0f;
    for (uint8_t index = 0; index < 3; ++index) {
        int val = output_ids[index];
        *result_id = (outputs[val] > biggest) ? index : *result_id;
        biggest = (outputs[val] > biggest) ? outputs[val] : biggest;
    delete[] completed;
    delete[] values;
    delete[] outputs;
__global__ void EvaluateNetworks(float* __restrict__ rollingdata, Network* __restrict__ d_networks, int input_num, uint8_t stepsPerThread, int datasize, TradesForPopulation* tradeee, int pop_idx) {
    int idx = threadIdx.x + blockIdx.x * blockDim.x;
    Network* net = &d_networks[pop_idx];
    Trades* trade = &tradeee->jaja[pop_idx];
    if (net == nullptr || net->output_ids == nullptr || net->Connections == nullptr) {
        printf("Error: Null pointer in network\n");
        return;
    if (trade == nullptr || trade == NULL) {
        printf("Error: Null pointer in trades - %i\n", pop_idx);
        return;
    for (int i = idx * stepsPerThread; i < (idx + 1) * stepsPerThread; ++i) {
        if (i >= datasize) return;
        int start = i * input_num;
        int finish = (i+1) * input_num;
        float* data_chnk = new float[input_num];
        if (data_chnk == nullptr || data_chnk == NULL) {
            printf("Memory allocation failed for data_chnk\n");
            return;
        for (int ehe = start; ehe < finish; ++ehe) {
            data_chnk[ehe-start] = rollingdata[ehe];
        uint8_t result_id = 5;
        GetNetworkOutput(data_chnk, net, net->output_ids, &result_id);
        trade->traades[i] = result_id;
        delete[] data_chnk;
I tried to replace new with extern __shared__ but it gave me an illegal memory access was encountered error. I looked into the documentation and 1. Introduction — CUDA C++ Programming Guide says you have to specify the required shared memory size at the kernel via <<<blocks, threadsperblock, requiredmemsize>>> but the problem is I’m launching the kernel in a loop and I need to copy the memory from device to host and it slows down the proccess. Is there any way to use extern __shared__ instead of heap memory without specifing the required shared memory size at the kernel call? I want to use shared memory for data_chnk, values, outputs and completed variables.
Here’s the loop that I’m calling kernel
for (int i = 0; i < population_size; ++i) {
    EvaluateNetworks<<<evaulation_blocks, threadsPerBlock>>>(d_rolling_data, d_networks, input_num, stepsPerThread, (sizeff - ws), d_traades_for_population, i);
gpuErrchk(cudaDeviceSynchronize());
To specify the required shared mem size I have to copy d_networks[i].num_connections and d_networks[i].num_neurons into host and then calculate the required size and call the function every time.
Also one more question, do you really think that it will speed up the function like 50x - 100x?
You allocate the maximum that you need. Or the maximum possible. You can start less blocks per SM, but otherwise you are fine.
For high performance you have to optimize the access that there are no bank conflicts, i.e. for each access each lane (thread of a warp) accesses a different lane, which is simple to achieve, if each thread uses its own part of shared memory.
Fully optimizing programs like yours could mean its own task, much more complicated than writing the function in the first place. You have to strategically think about each memory access and possibly rewriting the function. It could be that the optimal program is 10 times longer and does not look in any way as your current kernel (and could take weeks for a specialist). But perhaps fully optimizing it is not necessary. Just solve a few bottlenecks. Current Cuda is much more forgiving than 10-15 years ago.
This is not an answer on how to use shared memory in your kernel, but rather a general advice on how to improve your kernel.
First, all allocation sizes only depend on the kernel inputs. You can move all the allocations to the begin of the kernel. That is, move float* data_chnk = new float[input_num]; before the for-loop. Additionally, do not allocate
within the device function, but also allocate in once in the kernel before the for-loop, and pass pointers to the function.
Second, by having each thread work on a different chunk of memory, the kernel performs many uncoalesced memory accesses which reduces performance. You could use a warp or a thread block instead. Depending on your choice, you then only need to allocate temporary storage per warp or block, not per thread.
