Using Sionna CDL-D/E channel models with PyAerial 26.1
We are using PyAerial 26.1 on GH200. According to tutorials, built-in fading-channel generator currently supports CDL-A, CDL-B, and CDL-C only, but our work requires CDL-D,E also.
In previous PyAerial 25.3.2, the container build created a TensorFlow wheel using the NVIDIA TensorFlow image and installed sionna-no-rt==1.0.2. But it seems these TensorFlow and Sionna build sections have been removed in PyAerial 26.1. Sionna 2.0.1 also required python 3.11+, but currently 26.1 uses python 3.10 packages.
1.What is the recommended method for generating CDL-D and CDL-E channels with PyAerial 26.1?
2. Are CDL-D and CDL-E addition planned for the PyAerial fading-channel generator?
Thanks for your question. The current version of pyAerial does not support CDL-D and CDL-E and we will plan to add it in a future release. A temporary workaround is to use Sionna as follows:
  1. Generate the pyAerial PUSCH/PDSCH frequency-domain signal.
  2. Apply the CDL-D/E channel using Sionna.
  3. Convert and reorder Sionna’s output to the format expected by pyAerial.
  4. Pass the resulting received grid to the pyAerial receiver.
