Using texture
I tried to use texture memory using this simple code, but the texture is not returning the correct values; I suspect a problem with the index for accessing the texture.
texture<float, 2, cudaReadModeElementType> texGaborU;
__global__ void GaborKernel( Complex* in ,int width ,int height ,Complex* maps )
	unsigned int x	= blockIdx.x*blockDim.x + threadIdx.x;
	unsigned int y	= blockIdx.y*blockDim.y + threadIdx.y;
	float u ,v;
	unsigned int i,j;
	for ( j = 0; j < NO_OF_ORIENTS; j++ )
		u = x / (float)width;
		v = <b>(j*height + y) / (float)(NO_OF_ORIENTS*height)</b>;
		for ( i = 0; i < NO_OF_BANDS; i++ )
			//some operation using texture
			in[y*width + x] = tex2D(texGaborU ,u ,v);
float *h_gaborMaskU = (float *)malloc( NO_OF_ORIENTS * width*height*sizeof(float));
	cudaArray* cu_gaborU = NULL;
	CUDA_SAFE_CALL( cudaMallocArray( &cu_gaborU, &channelDesc, <b>width ,NO_OF_ORIENTS*height</b> ));
	CUDA_SAFE_CALL( cudaMemcpyToArray( cu_gaborU, 0, 0, h_gaborMaskU ,NO_OF_ORIENTS*width*height*sizeof(float), cudaMemcpyHostToDevice));
	texGaborU.addressMode[0] = cudaAddressModeClamp;
	texGaborU.addressMode[1] = cudaAddressModeClamp;
	texGaborU.filterMode	= cudaFilterModePoint;
	texGaborU.normalized	= true;
	CUDA_SAFE_CALL( cudaBindTextureToArray( texGaborU, cu_gaborU, channelDesc) );
	//call to gabor kernel
