Sorry i’m a newbie in all of that, hope it’s not a problem.
I’m using an embedded camera (from e-con systems) wich is plugged on J49 (CAM1)
to use it i’ve downloaded the software provided by e-con systems and it works great.
I’m using too an ADC for audio input which uses I2S protocol.
when i’m modifiying pin configurations with “jetson-io.py” to reconfigure pins in i2s4, the camera stop working.
Does anyone have an answer to this? :/
thanks in advance for your answers and sorry for my bad English!
fragment@0 {
target-path ="/";
__overlay__ {
my-custom-property = "This is my overlay";
and here is the error when i tried to applied this overlay:
File “/opt/nvidia/jetson-io/config-by-hardware.py”, line 125, in
main()
File “/opt/nvidia/jetson-io/config-by-hardware.py”, line 117, in main
dtbo = configure_jetson(jetson, header, hw)
File “/opt/nvidia/jetson-io/config-by-hardware.py”, line 55, in configure_jetson
% (hw, header))
NameError: No configuration found for Overlay Jetson Nano on Jetson 40pin Header!
how can i go further? maybe the .dts has an error?
Hello again @JerryChang !
i’ve changed the jetson-header-name, but same error…
user@jetson2:~$ sudo /opt/nvidia/jetson-io/config-by-hardware.py -n “My Jetson Overlay”
main()
% (hw, header))
NameError: No configuration found for My Jetson Overlay on Jetson 40pin Header!
if you think there is another way i’ll be glad!
i’ll try other header names!
maybe should I add something in the “fragment” part?
you should create a file named my-overlay.dts on the target platform, the file should also contain the property, overlay-name = "My Jetson Overlay"; after that, please compile the DTS source file into an overlay file, my-overlay.dtbo, and place it under /boot/, then python script, config-by-hardware.py -n "My Jetson Overlay" should recognize the file.
