is it possible to provide the --jobs or -j parameter for simultaneously execution? If yes where can I enter this -j option.
Regards
Regards
Solved!
Project -> Properties -> in the left frame click on “Build” --> in the right frame select tab “Behaviour” --> enable option “Enable parallel build”
In my case this option speeds up the make process up to 4 times! 7 seconds instead of 28…
