I am trying use the the omni client api from an Azure web app however I am having some issues connecting. My setup works fine on my local machine but the deployed web app fails to establish a connection. I have included the logs from the failed connection below.
Initialized Nucleus API v11.20-7193ae28
Request 1: readFile(omniverse://mynucleus.co.uk/myusd.usd) starting
mynucleus.co.uk: Starting
wss://mynucleus.co.uk/omni/discovery: Searching for services
connecting to wss://mynucleus.co.uk:443/omni/discovery
4276: created socket for mynucleus.co.uk:443
4276: Failed to set socket tcp interval
4276: Failed to set socket tcp count
Attempting to load mtls.toml file from C:\local\UserProfile.nvidia-omniverse\config\mtls.toml
mtls.toml file is not loaded
4276: not using mTLS since client certificate and private key were not provided
4276: send id=1 DiscoverySearch.find 000002064881C570
4276: send id=2 DiscoverySearch.find 000002064881C570
4276: send id=3 DiscoverySearch.find 000002064881C570
4276: send id=4 DiscoverySearch.find 000002064881C570
ws://mynucleus.co.uk/omni/discovery: Searching for services
connecting to ws://mynucleus.co.uk:80/omni/discovery
4308: created socket for mynucleus.co.uk:80
4308: Failed to set socket tcp interval
4308: Failed to set socket tcp count
4308: send id=1 DiscoverySearch.find 000002064881C570
4308: send id=2 DiscoverySearch.find 000002064881C570
4308: send id=3 DiscoverySearch.find 000002064881C570
4308: send id=4 DiscoverySearch.find 000002064881C6E0
ws://mynucleus.co.uk:3333: Searching for services
connecting to ws://mynucleus.co.uk:3333/
4312: created socket for mynucleus.co.uk:3333
4312: Failed to set socket tcp interval
4312: Failed to set socket tcp count
4312: send id=1 DiscoverySearch.find 000002064881C570
4312: send id=2 DiscoverySearch.find 000002064881C570
4312: send id=3 DiscoverySearch.find 000002064881C570
4312: send id=4 DiscoverySearch.find 000002064881C570
Creating Client
POST https://mynucleus.co.uk/omni/auth/api/device/authorize (timeout=60)
Running Client Thread
https://mynucleus.co.uk/omni/auth/api/device/authorize received response code 400: Failed to open a WebSocket connection: did not receive a valid HTTP request.
