Using the VST UI for viewing a live camera feed increases RAM usage until the system hangs
When we used VST UI to add the video source (rtsp://:8558/mystream) to the VST service the video source is added successfully. However, we are facing the following issues:
The RAM consumption on our Jetson device tends to start increasing quickly , when we enable the live stream or visualize the recorded data in the sample web app. This happens to a point where the system hangs.
Kindly let us know the solution to the aforementioned issues.
Thanks for reporting the issue. I will check it and feedback here.
Can you have a try change below setting in ai_nvr/config/vst/vst_config.json?
Change: “use_webrtc_inbuilt_encoder”: “h264”, to “use_webrtc_inbuilt_encoder”: “”,
Thanks @kesong, It works.
