Is it possible to use thrust with device data, which is allocated with the driver API ?
I have some arrays on the GPU, allocated with the driver API I want to sort … using custom compare function.
I am loading my source from a PTX file.
Is this possible ? Is there any example for stuff like that ?
Jofo
March 9, 2016, 12:01pm
2
I am bumping this because I have run into the same problem. I am using driver API and need to sort an array of uint64_t’s (CUdeviceptr), but this construct
thrust::device_ptr<uint64_t> ptr(somethingOfCudeviceptrType);
fails to compile. Is Thrust restricted only to runtime API, or is there another way to make it work under driver API?
Thrust expects runtime API constructs.
You can convert a CUdeviceptr to an ordinary pointer and use it with thrust, I believe.
[url]https://devtalk.nvidia.com/default/topic/452963/driver-api-and-runtime-api-interoperability/[/url]
