Hi, I have a problem of declaring an array in shared memory. GTX480 has 48k shared memory per block, but when I declare an array of 32k data with each of which 1 byte, it throws out errors as follow when compile.
typedef struct {
char mem : 1;
} bit_t;
shared bit_t data[32768];
ptxas error : Entry function ‘_Z6kernelPcP5bit_tii’ uses too much shared data (0x8018 bytes + 0x10 bytes system, 0x4000 max)
Based on the report, 0x4000 means only 16k for max. Then how do I use the rest part of the shared memory?
But I’ve tried to declare multiple small arrays, like
Then how to set it based on SDK that Nvidia Provides? in common.mk?
I notice that there are lines in common.mk listed below stating the sm_20 and sm_10, but I don’t know how to check which one I am using and how to change it. The card is GTX480.
Compiler-specific flags (by default, we always use sm_10 and sm_20), unless we use the SMVERSION template
You will already use the most fitting one but as seibert says its better to use your own makefiles. A few lines and you know for sure what CC you are using :) But you might also have to call cudaFuncSetCacheConfig to set smem to 48k and L1 to 16k.
