I’ve still got the same checksum mismatch with same stored (1214729159) and calculated (4272926173) values. Here’s a longer snippet:
2018-12-05 17:26:36.716913: W tensorflow/core/framework/op_kernel.cc:1273] OP_REQUIRES failed at save_restore_v2_ops.cc:184 : Data loss: Checksum does not match: stored 1214729159 vs. calculated on the restored bytes 4272926173
File “freezeGraph.py”, line 9, in
saver.restore(sess,tf.train.latest_checkpoint(“./ckpt/”))
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/saver.py”, line 1546, in restore
{self.saver_def.filename_tensor_name: save_path})
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/client/session.py”, line 929, in run
run_metadata_ptr)
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/client/session.py”, line 1152, in _run
feed_dict_tensor, options, run_metadata)
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/client/session.py”, line 1328, in _do_run
run_metadata)
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/client/session.py”, line 1348, in _do_call
raise type(e)(node_def, op, message)
tensorflow.python.framework.errors_impl.DataLossError: Checksum does not match: stored 1214729159 vs. calculated on the restored bytes 4272926173
[[node save/RestoreV2 (defined at freezeGraph.py:8) = RestoreV2[dtypes=[DT_FLOAT, DT_FLOAT, DT_FLOAT, DT_FLOAT, DT_FLOAT, …, DT_FLOAT, DT_FLOAT, DT_FLOAT, DT_FLOAT, DT_FLOAT], _device=“/job:localhost/replica:0/task:0/device:CPU:0”](_arg_save/Const_0_0, save/RestoreV2/tensor_names, save/RestoreV2/shape_and_slices)]]
Caused by op u’save/RestoreV2’, defined at:
File “freezeGraph.py”, line 8, in
saver = tf.train.import_meta_graph(meta_path)
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/saver.py”, line 1674, in import_meta_graph
meta_graph_or_file, clear_devices, import_scope, **kwargs)[0]
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/saver.py”, line 1696, in _import_meta_graph_with_return_elements
**kwargs))
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/meta_graph.py”, line 806, in import_scoped_meta_graph_with_return_elements
return_elements=return_elements)
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/util/deprecation.py”, line 488, in new_func
return func(*args, **kwargs)
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/importer.py”, line 442, in import_graph_def
_ProcessNewOps(graph)
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/importer.py”, line 234, in _ProcessNewOps
for new_op in graph._add_new_tf_operations(compute_devices=False): # pylint: disable=protected-access
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/ops.py”, line 3440, in _add_new_tf_operations
for c_op in c_api_util.new_tf_operations(self)
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/ops.py”, line 3299, in _create_op_from_tf_operation
ret = Operation(c_op, self)
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/ops.py”, line 1770, in init
self._traceback = tf_stack.extract_stack()
DataLossError (see above for traceback): Checksum does not match: stored 1214729159 vs. calculated on the restored bytes 4272926173
