I have an OpenACC enabled fortran application that uses unified memory. How do I enable prefetching (akin to using cudaMemPrefetchAsync())?
regards,
Naga
regards,
Naga
Hi Naga,
You can use the CUDA Fortran interfaces to call “cudaMemPrefetchAsync” directly by using the “cudafor” module and compiling with “-Mcuda”.
From the CUDA Fortran Programming Guide: http://www.pgroup.com/resources/docs/17.10/x86/cuda-fortran-prog-guide/index.htm
4.8.37. cudaMemPrefetchAsync
integer function cudaMemPrefetchAsync(devptr, count, device, stream)
cudaMemPrefetchAsync prefetches memory to the specified destination device. devptr may be any managed memory scalar or array, of a supported type specified in Device Code Intrinsic Datatypes. The count is in terms of elements. Alternatively, devptr may be of TYPE(C_DEVPTR), in which case the count is in terms of bytes.
The device argument specifies the destination device. The stream argument specifies which stream to enqueue the prefetch operation on.
Passing in cudaCpuDeviceId for the device, which is defined as a parameter in the cudafor module, will prefetch the data to CPU memory.
To get the CUDA device pointer, call the CUDA routine from within an OpenACC “host_data” region. Something like:
integer(acc_handle_kind) :: stream
! get the CUDA stream id for the OpenACC async queue
stream = acc_get_cuda_stream(asyncQueueNumber)
!$acc host_data use_device(Arr)
call cudaMemPrefetchAsync(Arr, ArrSizeInBytes, deviceNumber, stream)
!$acc end host_data
Hope this helps,
Mat
Thanks Matt,
I get the following error when I compile with -Mcuda
pgf95 -acc -c -Minfo=accel -ta=tesla:cc60 -ta=tesla:managed -Mcuda -lm PSMHD3-cufftacc.f95
PGF90-S-0084-Illegal use of symbol cudamemprefetchasyncr8 - attempt to CALL a FUNCTION (PSMHD3-cufftacc.f95: 1276)
I am calling it in the code as below:
prefetchsize = (Nx + 2)NyNz
!$acc host_data use_device(rho_ux)
call cudaMemPrefetchAsync(rho_ux,prefetchsize,0,stream)
!$acc end host_data
regards,
Naga
Hi Matt,
I changed the code as follows:
i= cudaMemPrefetchAsync(rho_ux,prefetchsize,0,stream)
!$acc end host_data
Now it compiles.
regards,
Naga
