Hardware: Orin AGX
Jetpack: 5.0.2
Running deepstream-l4t:6.0.1-triton docker
We have successfully used vimbasrc in gstreamer pipelines.
It is a plugin that allows gstreamer to take inputs from specific cameras.
We tend to use video/x-raw, format=GRAY8 because of the color limitations of our camera.
These are the other possible caps of the source pad of the element:
video/x-raw format: { I420, YV12, YUY2, UYVY, AYUV, VUYA, RGBx, BGRx, xRGB, xBGR, RGBA, BGRA, ARGB, ABGR, RGB, BGR, Y41B, Y42B, YVYU, Y444, v210, v216, Y210, Y410, NV12, NV21, GRAY8, GRAY16_BE, GRAY16_LE, v308, RGB16, BGR16, RGB15, BGR15, UYVP, A420, RGB8P, YUV9, YVU9, IYU1, ARGB64, AYUV64, r210, I420_10BE, I420_10LE, I422_10BE, I422_10LE, Y444_10BE, Y444_10LE, GBR, GBR_10BE, GBR_10LE, NV16, NV24, NV12_64Z32, A420_10BE, A420_10LE, A422_10BE, A422_10LE, A444_10BE, A444_10LE, NV61, P010_10BE, P010_10LE, IYU2, VYUY, GBRA, GBRA_10BE, GBRA_10LE, BGR10A2_LE, GBR_12BE, GBR_12LE, GBRA_12BE, GBRA_12LE, I420_12BE, I420_12LE, I422_12BE, I422_12LE, Y444_12BE, Y444_12LE, GRAY10_LE32, NV12_10LE32, NV16_10LE32, NV12_10LE40 }
video/x-bayer format: { (string)bggr, (string)grbg, (string)gbrg, (string)rggb }
We could use advice on how to implement that same plugin as an input for a deepstream pipeline.
