Using VPI Remap in a Custom DeepStream Plugin
• Hardware Platform (Jetson / GPU) Jetson Xavier AGX
• DeepStream Version 6.0
• NVIDIA GPU Driver Version (valid for GPU only) 10.2
Hi, I’m writing a custom DeepStream plugin in which i do a recitfication of a stereo camera.
I do it with the Remap VPI on CUDA.
I have two images ( left and right) which have a size of 2448 * 2060.
The remap process takes about 10 - 12 ms, which I think is to long.
Can I expect faster results?
It looks like this is a VPI performance issue, not related to Deepstream.
Please correct me if anything is missing.
Based on the performance table below, the remap algorithm is expected to take < 1ms on a 1920x1080 input.
https://docs.nvidia.com/vpi/algo_remap.html#algo_remap_perf
So your score is somehow much slower than our profiling result.
Would you mind trying the below script to boost device performance first?
https://docs.nvidia.com/vpi/algo_performance.html#maxout_clocks
Thank you for your fast respone.
You are right and I also had a look at the performance table.
I ran the script and now the performance is twice as fast but still takes up to 4.5ms for both images. I should be faster right?
Is the time only for remap algorithm?
If yes, would you mind sharing an example so we can check if anything differernt?
Yes, the measured time is only for the remap algorithm.
Sure, here is an example:
I create the map with opencv as you can see in this function:
void RectifyUtils::generate_map() {
	// create undistortion and rectification maps for left and right camera
	cv::Size image_size(_input_frame_width, _input_frame_height);
	cv::stereoRectify(_M1, _D1, _M2, _D2, image_size, _R, _T, _R1, _R2, _P1, _P2, _Q,
					  cv::CALIB_ZERO_DISPARITY, 1.0, image_size, &_validRoi[0], &_validRoi[1]);
	cv::initUndistortRectifyMap(_M1, _D1, _R1, _P1, image_size, CV_32FC1, _map[0][0], _map[0][1]);
	cv::initUndistortRectifyMap(_M2, _D2, _R2, _P2, image_size, CV_32FC1, _map[1][0], _map[1][1]);
	memset(&_warp_map_m1, 0, sizeof(_warp_map_m1));
    memset(&_warp_map_m2, 0, sizeof(_warp_map_m2));
    _warp_map_m1.grid.numHorizRegions  = 1;
    _warp_map_m1.grid.numVertRegions   = 1;
    _warp_map_m1.grid.regionWidth[0]   = _input_frame_width;
    _warp_map_m1.grid.regionHeight[0]  = _input_frame_height;
    _warp_map_m1.grid.horizInterval[0] = 1;
    _warp_map_m1.grid.vertInterval[0]  = 1;
	_warp_map_m2.grid.numHorizRegions  = 1;
    _warp_map_m2.grid.numVertRegions   = 1;
    _warp_map_m2.grid.regionWidth[0]   = _input_frame_width;
    _warp_map_m2.grid.regionHeight[0]  = _input_frame_height;
    _warp_map_m2.grid.horizInterval[0] = 1;
    _warp_map_m2.grid.vertInterval[0]  = 1;
	vpiWarpMapAllocData(&_warp_map_m1);
	check_status(vpiWarpMapGenerateIdentity(&_warp_map_m1), "vpiWarpMapGenerateIdentity");
	vpiWarpMapAllocData(&_warp_map_m2);
	check_status(vpiWarpMapGenerateIdentity(&_warp_map_m2), "vpiWarpMapGenerateIdentity");
    // fill up maps for master and slave transformation
    for (int i = 0; i < _map[0][0].rows; i++)
        VPIKeypoint *row_master = (VPIKeypoint *)((uint8_t *)_warp_map_m1.keypoints + _warp_map_m1.pitchBytes * i);
		VPIKeypoint *row_slave = (VPIKeypoint *)((uint8_t *)_warp_map_m2.keypoints + _warp_map_m2.pitchBytes * i);
        int j;
        for (j = 0; j < _map[0][0].cols; j++)
            row_master[j].x = _map[1][0].at<float>(i,j);
            row_master[j].y = _map[1][1].at<float>(i,j);
            row_slave[j].x = _map[0][0].at<float>(i,j);
            row_slave[j].y = _map[0][1].at<float>(i,j);
	check_status(vpiCreateRemap(VPI_BACKEND_CUDA, &_warp_map_m1, &_warp_m1), "vpiCreateRemap");
	check_status(vpiCreateRemap(VPI_BACKEND_CUDA, &_warp_map_m2, &_warp_m2), "vpiCreateRemap");
This is how I wrap the EGL Image to VPI:
(Note: FrameConatainer is a struct containing NvBufSurface and NvDsFrameMeta)
int RectifyUtils::frame_cont_to_vpi(std::vector<FrameContainer> *frame_cont)
	int temp_batch_size = 0;
	for(size_t n = 0; n < frame_cont->size(); n++) {
		if (frame_cont->at(n).data.nvds.meta->source_id == 0)
			// map master frame as egl image
			if (NvBufSurfaceMapEglImage(frame_cont->at(n).data.nvds.surface, 0))
				GST_ERROR("Failed to map EGLImage");
				return -1;
			_vct_input_imgs.at(n).source_id = 0;
			if (!_vct_input_imgs.at(n).is_wrapper_created)
				check_status(vpiImageCreateEGLImageWrapper(frame_cont->at(n).data.nvds.surface->surfaceList[n].mappedAddr.eglImage,
															nullptr, VPI_BACKEND_CUDA | VPI_BACKEND_VIC , &_vct_input_imgs.at(n).img), "vpiImageCreateEGLImageWrapper");
				_vct_input_imgs.at(n).is_wrapper_created = true;
			} else {
				check_status(vpiImageSetWrappedEGLImage(_vct_input_imgs.at(n).img, frame_cont->at(n).data.nvds.surface->surfaceList[0].mappedAddr.eglImage), "vpiImageSetWrappedEGLImage");
		} else {
			// map slave frame as egl image
			if (NvBufSurfaceMapEglImage(frame_cont->at(n).data.nvds.surface, (0+n)))
				return -1;
			_vct_input_imgs.at(n).source_id = 1;
				check_status(vpiImageCreateEGLImageWrapper(frame_cont->at(n).data.nvds.surface->surfaceList[0+n].mappedAddr.eglImage,
			} else {
				check_status(vpiImageSetWrappedEGLImage(_vct_input_imgs.at(n).img, frame_cont->at(n).data.nvds.surface->surfaceList[0+n].mappedAddr.eglImage), "vpiImageSetWrappedEGLImage");
		temp_batch_size++;
	return temp_batch_size;
And this is how I run the Remap algorithm:
(Note: this function takes up to 4.5 - 5.5 ms. _current_batch_size is 2)
void RectifyUtils::undistort_rectify()
	for (uint8_t i = 0; i < _current_batch_size; i++)
		if (_vct_input_imgs.at(i).source_id == 0)
			check_status(vpiSubmitRemap(_cuda_stream, VPI_BACKEND_CUDA, _warp_m1, _vct_input_imgs.at(i).img, _vct_rectified_imgs.at(i).img, VPI_INTERP_LINEAR, VPI_BORDER_ZERO, 0), "vpiSubmitRemap");
		} else {
			check_status(vpiSubmitRemap(_cuda_stream, VPI_BACKEND_CUDA, _warp_m2, _vct_input_imgs.at(i).img, _vct_rectified_imgs.at(i).img, VPI_INTERP_LINEAR, VPI_BORDER_ZERO, 0), "vpiSubmitRemap");
		_vct_rectified_imgs.at(i).source_id = _vct_input_imgs.at(i).source_id;
	vpiStreamSync(_cuda_stream);
Thanks for the update.
We are going to reproduce this issue internally.
Will share more information with you later.
Sorry for the late update.
Could you also share which input data format you use?
According to the different data formats, the expected execution time of remap algorithm will be different.
The input data type is NV12.
We tried to test your source but meet the _map undefined error.
Could you share a complete source for us to reproduce?
main.cpp:66:45: error: expected primary-expression before ‘float’
We also test the remap algorithm with 2448 x 2060 NV12 input.
The performance is much better than the 4.5ms you reported.
Would you mind giving it a try? main.cpp (3.5 KB)
