Could you follow below topic to install PyTorch?
The package is built with CUDA and Jetson GPU architecture.
| YOLOv5 on Jetson Orin not use GPU | 4 | 1933 | November 9, 2022 | |
| Can I execute yolov5 on the GPU of JETSON AGX XAVIER? | 22 | 7907 | July 1, 2022 | |
| Tensorflow and PyTorch do not use GPU on Jetson Xavier AGX | 4 | 1560 | July 3, 2023 | |
| The GPU is not used when running detection with YOLOv5 | 4 | 624 | July 18, 2024 | |
| Unable to run YOLOv5 on Jetson Orin not use GPU and CUDA | 2 | 1203 | February 22, 2023 | |
| Installing PyTorch for CUDA 10.2 on Jetson Xavier NX for YOLOv5 | 19 | 9387 | September 21, 2021 | |
| Pytorch : Unable to Train YoloV5 on Jetson Orin AGX GPU (using CUDA) | 2 | 858 | September 18, 2023 | |
| Unable to install pytorch with cuda support on jetson AGX Xavier | 2 | 1258 | January 22, 2024 | |
| How to run customized YOLO V5 model on Nvidia Orin GPU cores | 4 | 660 | September 12, 2023 | |
| How to use GPU of NVIDIA Xavier NX Developer Kit | 6 | 389 | May 10, 2024 |
