hi all,
I need help, !!!
do you know where to find the -lcudpp64
error is
[codebox]/usr/bin/ld: cannot find -lcudpp64
collect2: ld returned 1 exit status
make: *** [lib/linux/libJCudpp-linux-x86_64.so] Error 255
[/codebox]
my makefile
[codebox]
Base name of the library (the parts that are specific
for OS and architecture will be appended)
DYNAMIC_LIB_BASE_NAME := JCudpp
C++ source files (compiled with c++)
CCFILES := JCudpp.cpp Logger.cpp
JNI includes
JNI_INCLUDES := -I/usr/java/jdk1.6.0_16/include -I/usr/java/jdk1.6.0_16/include/linux
For MacOS it seems to be something like that:
#JNI_INCLUDES := -I/usr/java/jdk1.6.0_16/Headers
Seems to be only required for MacOS: This should
be the path to the directory containing “libGLEW.a”
GL_LIB_PATH :=
Additional libraries needed by the project
USECUDPP := 1
Emulation mode flag, may also be set by calling
this makefile with
make -emu=1
emu := 1
Rules and targets
include common.mk[/codebox]
my common.mk
[codebox]###################################################
This is the common makefile from the CUDA samples provided by NVIDIA,
modified for compiling the JCuda shared libraries.
Copyright 1993-2006 NVIDIA Corporation. All rights reserved.
NOTICE TO USER:
This source code is subject to NVIDIA ownership rights under U.S. and
international Copyright laws.
NVIDIA MAKES NO REPRESENTATION ABOUT THE SUITABILITY OF THIS SOURCE
CODE FOR ANY PURPOSE. IT IS PROVIDED “AS IS” WITHOUT EXPRESS OR
IMPLIED WARRANTY OF ANY KIND. NVIDIA DISCLAIMS ALL WARRANTIES WITH
REGARD TO THIS SOURCE CODE, INCLUDING ALL IMPLIED WARRANTIES OF
MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE.
IN NO EVENT SHALL NVIDIA BE LIABLE FOR ANY SPECIAL, INDIRECT, INCIDENTAL,
OR CONSEQUENTIAL DAMAGES, OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS
OF USE, DATA OR PROFITS, WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE
OR OTHER TORTIOUS ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE
OR PERFORMANCE OF THIS SOURCE CODE.
U.S. Government End Users. This source code is a “commercial item” as
that term is defined at 48 C.F.R. 2.101 (OCT 1995), consisting of
“commercial computer software” and "commercial computer software
documentation" as such terms are used in 48 C.F.R. 12.212 (SEPT 1995)
and is provided to the U.S. Government only as a commercial end item.
Consistent with 48 C.F.R.12.212 and 48 C.F.R. 227.7202-1 through
227.7202-4 (JUNE 1995), all U.S. Government End Users acquire the
source code with only those rights set forth herein.
Common build script
.SUFFIXES : .cu .cu_dbg.o .c_dbg.o .cpp_dbg.o .cu_rel.o .c_rel.o .cpp_rel.o .cubin .ptx
Add new SM Versions here as devices with new Compute Capability are released
SM_VERSIONS := sm_10 sm_11 sm_12 sm_13
CUDA_INSTALL_PATH ?= /usr/local/cuda
ifdef cuda-install
CUDA_INSTALL_PATH := $(cuda-install)
endif
detect OS
OSUPPER = $(shell uname -s 2>/dev/null | tr [:lower:] [:upper:])
OSLOWER = $(shell uname -s 2>/dev/null | tr [:upper:] [:lower:])
‘linux’ is output for Linux system, ‘darwin’ for OS X
DARWIN = $(strip $(findstring DARWIN, $(OSUPPER)))
detect if 32 bit or 64 bit system
HP_64 = $(shell uname -m | grep 64)
Basic directory setup for SDK
(override directories only if they are not already defined)
SRCDIR ?= ./src/
ROOTDIR ?= .
ROOTOBJDIR ?= ./obj
LIBDIR := ./lib/$(OSLOWER)
CUDPP_INCLUDES :=
CUDPP_LIBRARIES :=
Build the final library name for JCuda
DYNAMIC_LIB := lib$(DYNAMIC_LIB_BASE_NAME)
ifeq ($(emu), 1)
DYNAMIC_LIB := $(DYNAMIC_LIB)Emu
endif
ifneq ($(DARWIN),)
DYNAMIC_LIB := $(DYNAMIC_LIB)-apple
else
DYNAMIC_LIB := $(DYNAMIC_LIB)-linux
endif
DYNAMIC_LIB := $(DYNAMIC_LIB)-x86
ifneq “$(strip $(HP_64))” “”
DYNAMIC_LIB := $(DYNAMIC_LIB)_64
endif
LIB_EXTENSION :=
ifneq ($(DARWIN),)
LIB_EXTENSION := .jnilib
else
LIB_EXTENSION := .so
endif
DYNAMIC_LIB := $(DYNAMIC_LIB)$(LIB_EXTENSION)
ifeq ($(USECUDPP), 1)
CUDPP_INCLUDES := -I./include
CUDPP_LIBRARIES := -L./lib
endif
Compilers
ifeq “$(strip $(HP_64))” “”
NVCC := $(CUDA_INSTALL_PATH)/bin/nvcc
else
endif
CXX := g++
CC := gcc
LINK := g++ -fPIC
Includes
JNI_INCLUDES = /usr/lib/jvm/java-6-sun-1.6.0.15/include/
INCLUDES += -I. -I./src -I$(CUDA_INSTALL_PATH)/include -I$(JNI_INCLUDES) -I$(JNI_INCLUDES)/linux $(CUDPP_INCLUDES)
#INCLUDES += -I. -I./src -I$(CUDA_INSTALL_PATH)/include $(JNI_INCLUDES) $(CUDPP_INCLUDES)
architecture flag for cubin build
CUBIN_ARCH_FLAG :=
Warning flags
CXXWARN_FLAGS := \
-W -Wall \
-Wimplicit \
-Wswitch \
-Wformat \
-Wchar-subscripts \
-Wparentheses \
-Wmultichar \
-Wtrigraphs \
-Wpointer-arith \
-Wcast-align \
-Wreturn-type \
-Wno-unused-function \
-fPIC \
$(SPACE)
CWARN_FLAGS := $(CXXWARN_FLAGS) \
-Wstrict-prototypes \
-Wmissing-prototypes \
-Wmissing-declarations \
-Wnested-externs \
-Wmain \
Compiler-specific flags
NVCCFLAGS :=
CXXFLAGS := $(CXXWARN_FLAGS)
CFLAGS := $(CWARN_FLAGS)
Common flags
COMMONFLAGS += $(INCLUDES) -DUNIX
Debug/release configuration
ifeq ($(dbg),1)
COMMONFLAGS += -g
NVCCFLAGS += -D_DEBUG
CXXFLAGS += -D_DEBUG
CFLAGS += -D_DEBUG
BINSUBDIR := debug
LIBSUFFIX := D
else
COMMONFLAGS += -O2
BINSUBDIR := release
LIBSUFFIX :=
NVCCFLAGS += --compiler-options -fno-strict-aliasing
CXXFLAGS += -fno-strict-aliasing
CFLAGS += -fno-strict-aliasing
endif
append optional arch/SM version flags (such as -arch sm_11)
#NVCCFLAGS += $(SMVERSIONFLAGS)
CUBIN_ARCH_FLAG :=
OpenGL is used or not (if it is used, then it is necessary to include GLEW)
ifeq ($(USEGLLIB),1)
ifneq ($(DARWIN),)
OPENGLLIB := -L/System/Library/Frameworks/OpenGL.framework/Libraries -lGL -lGLU $(GL_LIB_PATH)/libGLEW.a
else
OPENGLLIB := -lGL -lGLU -lX11 -lXi -lXmu
ifeq "$(strip $(HP_64))" ""
OPENGLLIB += -lGLEW -L/usr/X11R6/lib
else
OPENGLLIB += -lGLEW_x86_64 -L/usr/X11R6/lib64
endif
endif
CUBIN_ARCH_FLAG := -m64
endif
ifeq ($(USEGLUT),1)
ifneq ($(DARWIN),)
OPENGLLIB += -framework GLUT
else
OPENGLLIB += -lglut
endif
endif
ifeq ($(USEPARAMGL),1)
PARAMGLLIB := -lparamgl$(LIBSUFFIX)
endif
ifeq ($(USERENDERCHECKGL),1)
RENDERCHECKGLLIB := -lrendercheckgl$(LIBSUFFIX)
endif
CUDPPLIB := -lcudpp
else
CUDPPLIB := -lcudpp64
endif
CUDPPLIB := $(CUDPPLIB)$(LIBSUFFIX)
CUDPPLIB := $(CUDPP_LIBRARIES) $(CUDPPLIB)
ifeq ($(emu), 1)
CUDPPLIB := $(CUDPPLIB)_emu
endif
endif
Libs
LIB := -L$(CUDA_INSTALL_PATH)/lib -L$(LIBDIR)
else
LIB := -L$(CUDA_INSTALL_PATH)/lib64 -L$(LIBDIR)
endif
If dynamically linking to CUDA and CUDART, we exclude the libraries from the LIB
ifeq ($(USECUDADYNLIB),1)
LIB += ${OPENGLLIB} $(PARAMGLLIB) $(RENDERCHECKGLLIB) $(CUDPPLIB) ${LIB} -ldl -rdynamic
else
static linking, we will statically link against CUDA and CUDART
ifeq ($(USEDRVAPI),1)
LIB += -lcuda ${OPENGLLIB} $(PARAMGLLIB) $(RENDERCHECKGLLIB) $(CUDPPLIB) ${LIB}
else
LIB += -lcudart ${OPENGLLIB} $(PARAMGLLIB) $(RENDERCHECKGLLIB) $(CUDPPLIB) ${LIB}
endif
endif
ifeq ($(USECUFFT),1)
ifeq ($(emu),1)
LIB += -lcufftemu
else
LIB += -lcufft
endif
endif
ifeq ($(USECUBLAS),1)
ifeq ($(emu),1)
LIB += -lcublasemu
else
LIB += -lcublas
endif
endif
Device emulation configuration
ifeq ($(emu), 1)
NVCCFLAGS += -deviceemu
CUDACCFLAGS +=
BINSUBDIR := emu$(BINSUBDIR)
# consistency, makes developing easier
CXXFLAGS += -D__DEVICE_EMULATION__
CFLAGS += -D__DEVICE_EMULATION__
endif
Target library configuration for JCuda
TARGETDIR := $(LIBDIR)
TARGET := $(subst $(LIB_EXTENSION),$(LIBSUFFIX)$(LIB_EXTENSION),$(LIBDIR)/$(DYNAMIC_LIB))
LINKLINE = $(NVCC) -o $(TARGET) --shared $(OBJS) $(LIB)
NVCCFLAGS += --shared
check if verbose
ifeq ($(verbose), 1)
VERBOSE :=
else
VERBOSE := @
endif
Check for input flags and set compiler flags appropriately
ifeq ($(fastmath), 1)
NVCCFLAGS += -use_fast_math
endif
ifeq ($(keep), 1)
NVCCFLAGS += -keep
NVCC_KEEP_CLEAN := *.i* *.cubin *.cu.c *.cudafe* *.fatbin.c *.ptx
endif
ifdef maxregisters
NVCCFLAGS += -maxrregcount $(maxregisters)
endif
Add cudacc flags
NVCCFLAGS += $(CUDACCFLAGS)
Add common flags
NVCCFLAGS += $(COMMONFLAGS)
CXXFLAGS += $(COMMONFLAGS)
ifeq ($(nvcc_warn_verbose),1)
NVCCFLAGS += $(addprefix --compiler-options ,$(CXXWARN_FLAGS))
endif
Set up object files
OBJDIR := $(ROOTOBJDIR)/$(BINSUBDIR)
OBJS += $(patsubst %.cpp,$(OBJDIR)/%.cpp.o,$(notdir $(CCFILES)))
OBJS += $(patsubst %.c,$(OBJDIR)/%.c.o,$(notdir $(CFILES)))
OBJS += $(patsubst %.cu,$(OBJDIR)/%.cu.o,$(notdir $(CUFILES)))
Set up cubin output files
CUBINDIR := $(SRCDIR)data
CUBINS += $(patsubst %.cu,$(CUBINDIR)/%.cubin,$(notdir $(CUBINFILES)))
Set up PTX output files
PTXDIR := $(SRCDIR)data
PTXBINS += $(patsubst %.cu,$(PTXDIR)/%.ptx,$(notdir $(PTXFILES)))
Rules
$(OBJDIR)/%.c.o : $(SRCDIR)%.c $(C_DEPS)
$(VERBOSE)$(CC) $(CFLAGS) -o $@ -c $<
$(OBJDIR)/%.cpp.o : $(SRCDIR)%.cpp $(C_DEPS)
$(VERBOSE)$(CXX) $(CXXFLAGS) -o $@ -c $<
$(OBJDIR)/%.cu.o : $(SRCDIR)%.cu $(CU_DEPS)
$(VERBOSE)$(NVCC) $(NVCCFLAGS) $(SMVERSIONFLAGS) -o $@ -c $<
$(CUBINDIR)/%.cubin : $(SRCDIR)%.cu cubindirectory
$(VERBOSE)$(NVCC) $(CUBIN_ARCH_FLAG) $(NVCCFLAGS) $(SMVERSIONFLAGS) -o $@ -cubin $<
$(PTXDIR)/%.ptx : $(SRCDIR)%.cu ptxdirectory
$(VERBOSE)$(NVCC) $(CUBIN_ARCH_FLAG) $(NVCCFLAGS) $(SMVERSIONFLAGS) -o $@ -ptx $<
The following definition is a template that gets instantiated for each SM
version (sm_10, sm_13, etc.) stored in SMVERSIONS. It does 2 things:
1. It adds to OBJS a .cu_sm_XX.o for each .cu file it finds in CUFILES_sm_XX.
2. It generates a rule for building .cu_sm_XX.o files from the corresponding
.cu file.
The intended use for this is to allow Makefiles that use common.mk to compile
files to different Compute Capability targets (aka SM arch version). To do
so, in the Makefile, list files for each SM arch separately, like so:
CUFILES_sm_10 := mycudakernel_sm10.cu app.cu
CUFILES_sm_12 := anothercudakernel_sm12.cu
define SMVERSION_template
OBJS += $(patsubst %.cu,$(OBJDIR)/%.cu_$(1).o,$(notdir $(CUFILES_$(1))))
$(OBJDIR)/%.cu_$(1).o : $(SRCDIR)%.cu $(CU_DEPS)
$(VERBOSE)$(NVCC) -o $$@ -c $$< $(NVCCFLAGS) -arch $(1)
endef
This line invokes the above template for each arch version stored in
SM_VERSIONS. The call funtion invokes the template, and the eval
function interprets it as make commands.
$(foreach smver,$(SM_VERSIONS),$(eval $(call SMVERSION_template,$(smver))))
$(TARGET): makedirectories $(OBJS) $(CUBINS) $(PTXBINS) Makefile
$(VERBOSE)$(LINKLINE)
cubindirectory:
$(VERBOSE)mkdir -p $(CUBINDIR)
ptxdirectory:
$(VERBOSE)mkdir -p $(PTXDIR)
makedirectories:
$(VERBOSE)mkdir -p $(LIBDIR)
$(VERBOSE)mkdir -p $(OBJDIR)
$(VERBOSE)mkdir -p $(TARGETDIR)
tidy :
$(VERBOSE)find . | egrep "#" | xargs rm -f
$(VERBOSE)find . | egrep "\~" | xargs rm -f
clean : tidy
$(VERBOSE)rm -f $(OBJS)
$(VERBOSE)rm -f $(CUBINS)
$(VERBOSE)rm -f $(PTXBINS)
$(VERBOSE)rm -f $(TARGET)
$(VERBOSE)rm -f $(NVCC_KEEP_CLEAN)
clobber : clean
$(VERBOSE)rm -rf $(ROOTOBJDIR)[/codebox]
