I’m using R32 revision 4.3.
cat /etc/nv_tegra_release
R32 (release), REVISION: 4.3, GCID: 21589087, BOARD: t210ref, EABI: aarch64, DATE: Fri Jun 26 04:38:25 UTC 2020
I have tried /usr/share/doc/jetson-gpio-common/samples$ sudo ./run_sample.sh simple_out.py.
It doesn’t work.
./run_sample.sh: line 25: cd: /usr/share/doc/jetson-gpio-common/lib/python: No such file or directory
./run_sample.sh: line 58: /usr/share/doc/jetson-gpio-common/samples/simple_out.py: Permission denied
./run_sample.sh: line 58: exec: /usr/share/doc/jetson-gpio-common/samples/simple_out.py: cannot execute: Permission denied
======== Jetson Nano GPIO - JetsonHacks ==========
We can run the sample for simple output to control our LED:
$ cd /usr/share/doc/jetson-gpio-common/samples$ sudo ./run_sample.sh simple_out.py
How can I run this example?
Thank you.
