Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.0.8170
1.5.1.7815
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
Hi All,
Is there a table or document which gives following information ?
- How many documented HW accelerators are there on Xavier (and Orin) ? ISP, PVA, Codecs, OpticalFlow, DisplayHead etc?
- Details about capability of each accelerator. What can it accelerate ? E.g. can ISP do debayer, scale and rotate in one go ? What would be data path of such an operation in ISP ? Will it read bayer data from DDR or will it directly receive it from CSI interface ? Will it write debayered output to DDR or and then read it back for scaling or rotation ?
- What are recommended nvidia SDK/APIs to use those accelerators ? E.g. I am guessing that in order to accelerate codec functionality, we should use NvMedia ?
- Are recommended APIs safety certified (ASIL-D) ?
- What is recommended image buffer format to be used with these accelerators ?
- Can the accelerator feed or receive data from GPU - if so what is recommended buffer format and APIs to facilitate this ?
- Is there a list of opencv functions / operations which can be accelerated by ISP/ PVA or other accelerators ?
- Are there any performance numbers which compares time required by an opencv function/algorithm on Xavier CPU/iGPU/accelerator-which-can-accelerate-that-function.
Ideally I would prefer this information tabulated for Xavier and Orin side by side.
PS : Moving to this forum, from - Utilizing Pegasus HW Accelerators
