Here is lsblk
for the board:
$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 16M 1 loop
mmcblk0 179:0 0 29.1G 0 disk
├─mmcblk0p1 179:1 0 14G 0 part
├─mmcblk0p2 179:2 0 14G 0 part /
├─mmcblk0p3 179:3 0 4M 0 part
├─mmcblk0p4 179:4 0 4M 0 part
├─mmcblk0p5 179:5 0 512K 0 part
├─mmcblk0p6 179:6 0 512K 0 part
├─mmcblk0p7 179:7 0 512K 0 part
├─mmcblk0p8 179:8 0 512K 0 part
├─mmcblk0p9 179:9 0 3M 0 part
├─mmcblk0p10 179:10 0 3M 0 part
├─mmcblk0p11 179:11 0 2M 0 part
├─mmcblk0p12 179:12 0 4M 0 part
├─mmcblk0p13 179:13 0 4M 0 part
├─mmcblk0p14 179:14 0 604K 0 part
├─mmcblk0p15 179:15 0 604K 0 part
├─mmcblk0p16 179:16 0 1M 0 part
├─mmcblk0p17 179:17 0 1M 0 part
├─mmcblk0p18 179:18 0 2M 0 part
├─mmcblk0p19 179:19 0 2M 0 part
├─mmcblk0p20 179:20 0 6M 0 part
├─mmcblk0p21 179:21 0 6M 0 part
├─mmcblk0p22 179:22 0 2M 0 part
├─mmcblk0p23 179:23 0 128M 0 part
├─mmcblk0p24 179:24 0 128M 0 part
├─mmcblk0p25 179:25 0 63M 0 part
├─mmcblk0p26 179:26 0 512K 0 part
├─mmcblk0p27 179:27 0 256K 0 part
├─mmcblk0p28 179:28 0 256K 0 part
├─mmcblk0p29 179:29 0 80M 0 part
├─mmcblk0p30 179:30 0 80M 0 part
├─mmcblk0p31 179:31 0 512K 0 part
├─mmcblk0p32 259:0 0 512K 0 part
├─mmcblk0p33 259:1 0 300M 0 part
└─mmcblk0p34 259:2 0 317.8M 0 part
mmcblk0boot0 179:32 0 4M 1 disk
mmcblk0boot1 179:64 0 4M 1 disk
mmcblk0rpmb 179:96 0 4M 0 disk
mmcblk2 179:128 0 238.3G 0 disk
└─mmcblk2p1 179:129 0 238.3G 0 part /data
zram0 252:0 0 982.4M 0 disk [SWAP]
zram1 252:1 0 982.4M 0 disk [SWAP]
zram2 252:2 0 982.4M 0 disk [SWAP]
zram3 252:3 0 982.4M 0 disk [SWAP]
Let me back up and describe the incident that led to this. I had some arbitrary U-Boot based builds running on my system when I tried to switch to C-Boot only. The rootfs partitions had partition UUIDs that looked like:
$ sudo blkid
/dev/mmcblk0p1: UUID="3f285248-6467-42dc-9771-bb3963de52fa" TYPE="ext4" PARTLABEL="APP" PARTUUID="2a8137cb-0370-497a-8254-58a4f7e39954"
/dev/mmcblk0p2: UUID="70f681d8-2fdf-4a61-8b27-8284b1f26a63" TYPE="ext4" PARTLABEL="APP_b" PARTUUID="e118e918-6555-4df6-9ad3-a035fcf8e888"
On this system, slot 0
was the active boot chain.
I then made a fresh build (that should only be using C-boot) where the UUID in l4t-rootfs-uuid.txt
was 6a3a84d8-1a5d-469e-ac15-ba6548d8387d
. From this I generated an OTA update package. This package installed the kernel image and rootfs into the partitions corresponding to slot 1
On reboot C-Boot starts up, detects we are using slot 1
, and detects a Linux kernel image in the KERNEL_B
partition:
[0001.225] I> Welcome to Cboot
[0001.228] I> Cboot Version: t186-704e62f2
[0003.292] initializing target
[0003.295] calling apps_init()
[0003.298] starting app kernel_boot_app
[0003.321] I> found decompressor handler: lz4-legacy
[0003.325] I> decompressing BMP blob ...
[0003.337] I> Kernel type = Normal
[0003.340] I> ########## Fixed storage boot ##########
[0003.345] I> Loading kernel-bootctrl from partition
[0003.350] I> Loading partition kernel-bootctrl at 0xa8000000 from device(0x1)
[0003.364] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0003.371] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0003.378] I> A/B: bin_type (24) slot 1
[0003.393] I> Boot image size read from image header: 20f3008
[0003.399] I> Boot image load address: 0x80400000
[0003.403] I> Loading kernel_b from partition
[0003.407] I> Loading partition kernel_b at 0x80400000 from device(0x1)
[0004.353] I> T18x: Authenticate kernel (bin_type 24), max size 0x4000000
[0004.434] I> Decrypt the buffer ... [0004.437] W> tegrabl_decrypt_block: fuse (0x0) is not burnt to do encryption (0x4); skip decryption.
[0004.446] I> done
[0004.448] I> Checking boot.img header magic ... [0004.452] I> [OK]
[0004.454] I> kernel-dtb is already loaded
[0004.458] I> Validate kernel-dtb ...
[0004.461] I> T18x: Authenticate kernel-dtb (bin_type 21), max size 0x100000
[0004.469] I> Decrypt the buffer ... [0004.472] W> tegrabl_decrypt_block: fuse (0x0) is not burnt to do encryption (0x4); skip decryption.
[0004.481] I> done
[0004.483] I> Kernel hdr @0x80400000
[0004.486] I> Kernel dtb @0x80000000
[0004.489] I> decompressor handler not found
[0004.493] I> Copying kernel image (34619400 bytes) from 0x80400800 to 0x82800000 ... [0004.514] I> Done
[0004.516] I> Move ramdisk (len: 0) from 0x82505000 to 0x96830000
[0004.523] I> Updated bpmp info to DTB
[0004.528] I> Ramdisk: Base: 0x96830000; Size: 0x0
[0004.533] I> Updated initrd info to DTB
[0004.536] W> WARN: Fail to override "console=none" in commandline
[0004.542] I> Active rootfs suffix: _b
[0004.567] I> disabled_core_mask: 0xffffff0c
[0004.571] I> Active slot suffix: _b
[0004.575] I> add_boot_slot_suffix: slot_suffix = _b
[0004.579] I> Linux Cmdline: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware root=PARTUUID=6a3a84d8-1a5d-469e-ac15-ba6548d8387d rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt rootfs.slot_suffix=_b usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 no_console_suspend boot.slot_suffix=_b boot.ratchetvalues=0.2031647.1 vpr_resize bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1
You can see in kernel command-line that C-boot read from the kernel image that the root device is pointed to by the NEW UUID 6a3a84d8...
C-Boot then execs that kernel with the detected parameters and we start booting Linux:
[0005.106] I> Kernel EP: 0x82800000, DTB: 0x80000000
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.253-tegra (xxxx@xxxx) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Thu Mar 9 00:31:55 UTC 2023
[ 0.000000] Kernel command line: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware root=PARTUUID=6a3a84d8-1a5d-469e-ac15-ba6548d8387d rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt rootfs.slot_suffix=_b usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 no_console_suspend boot.slot_suffix=_b boot.ratchetvalues=0.2031647.1 vpr_resize bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1
Once the eMMC device is initialized the kernel begins to wait for the roots device with UUID 6a3a84d8...
[ 3.862003] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.866263] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.878101] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.911650] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 3.927499] mmc0: periodic cache flush enabled
[ 3.927505] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 3.927837] mmcblk0: mmc0:0001 DG4032 29.1 GiB
[ 3.927932] mmcblk0boot0: mmc0:0001 DG4032 partition 1 4.00 MiB
[ 3.932153] mmcblk0boot1: mmc0:0001 DG4032 partition 2 4.00 MiB
[ 3.932257] mmcblk0rpmb: mmc0:0001 DG4032 partition 3 4.00 MiB
[ 3.936993] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p
23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34
[ 5.190714] Waiting for root device PARTUUID=6a3a84d8-1a5d-469e-ac15-ba6548d8387d...
But the kernel ends up waiting forever because that partition UUID doesn’t exist in the eMMC GPT table. The kernel is hung now and only several reboot will force the boot loader to revert back to slot 0
This is where my idea to lock the UUIDs comes from. If I were to pre-set the above UUIDS like this:
$printf "2a8137cb-0370-497a-8254-58a4f7e39954" > l4t-rootfs-uuid.txt
$printf "e118e918-6555-4df6-9ad3-a035fcf8e888" > l4t-rootfs-uuid.txt_b
I would at least have real UUIDs that correspond to those on my target already.
I would still need to contend with the artifact builder only using the slot A kernel image. From my example above, the kernel image supplied for the update has the slot 0
UUID baked into it despite it, eventually, needing to be written to the slot 1
KERNEL_B
partition.
To answer your second questions of what I’m looking to achieve; The primary build process where I run
USE_UBOOT=0 ROOTFS_AB=1 ./flash.sh --no-flash jetson-tx2 mmcblk0p1
generates two kernel images
boot.img
which has root=PARTUUID=2a8137cb..
parameter baked in
boot.img_b
which has root=PARTUUID=e118e918..
parameter baked in
I then need to run l4t_generate_ota_package.sh
to build my update package. What this SHOULD build is two BUP update payloads:
- bup_payload # built using boot.img
- bup_payload_b # built using boot_img_b
Then I copy the update package to my target, extract it, and run nv_ota_start.sh
. That process SHOULD
- detect the updater target slot vs the active slot
- detect if we have multiple
bup_payload
images that correspond particular slots
- copy the proper payload to the proper partition
- copy
bup_payload
to the KERNEL_A partition if slot 0 is the target slot
- copy
bup_payload_b
to KERNEL_B partition if slot 1 is the target slot
Does that clearly explain what I’m trying to achieve?
