Hi there,
it seems the Jetson Nano Tegra 4.9.201 Kernel is also affected by this Linux Kernel Bug:
https://github.com/raspberrypi/linux/issues/2551
When you connect/disconnect a “Webcam” (in this case its an Elgato Camlink 4K Capture Card capturing into the gstreamer pipeline from an Sony Fdr-x3000 Action Cam) you get
[Sa Mai 22 21:23:18 2021] uvcvideo: Failed to resubmit video URB (-1).
[Sa Mai 22 22:23:12 2021] uvcvideo: Failed to resubmit video URB (-1).
[Sa Mai 22 22:23:13 2021] uvcvideo: Failed to resubmit video URB (-1).
And:
[So Mai 23 23:10:59 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:11:04 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:11:09 2021] retire_capture_urb: 4993 callbacks suppressed
[So Mai 23 23:11:14 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:11:19 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:11:24 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:11:29 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:11:34 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:11:39 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:11:44 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:11:49 2021] retire_capture_urb: 4993 callbacks suppressed
[So Mai 23 23:11:54 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:11:59 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:12:04 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:12:09 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:12:14 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:12:19 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:12:24 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:12:29 2021] retire_capture_urb: 4993 callbacks suppressed
[So Mai 23 23:12:34 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:12:39 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:12:44 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:12:49 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:12:54 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:12:59 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:13:04 2021] retire_capture_urb: 4993 callbacks suppressed
[So Mai 23 23:13:09 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:13:14 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:13:19 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:13:24 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:13:29 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:13:34 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:13:39 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:13:44 2021] retire_capture_urb: 4993 callbacks suppressed
[So Mai 23 23:13:49 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:13:54 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:13:59 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:14:04 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:14:09 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:14:14 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:14:19 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:14:24 2021] retire_capture_urb: 4993 callbacks suppressed
[So Mai 23 23:14:29 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:14:34 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:14:39 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:14:44 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:14:49 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:14:54 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:14:59 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:15:04 2021] retire_capture_urb: 4993 callbacks suppressed
[So Mai 23 23:15:09 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:15:14 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:15:19 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:15:24 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:15:29 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:15:34 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:15:39 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:15:44 2021] retire_capture_urb: 4993 callbacks suppressed
[So Mai 23 23:15:49 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:15:54 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:15:59 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:16:04 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:16:09 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:16:14 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:16:19 2021] retire_capture_urb: 4993 callbacks suppressed
[So Mai 23 23:16:24 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:16:29 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:16:34 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:16:39 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:16:44 2021] retire_capture_urb: 4994 callbacks suppressed
[So Mai 23 23:16:49 2021] retire_capture_urb: 4994 callbacks suppressed
Will this be fixed in a future Kernel Release ?
KR
Stoney
