UVM performance with and without CPU population
I have observed that the performance of UVM fluctuates significantly based on CPU population.
In my test, I allocated two 40GB buffers on a 40GB A100 GPU. I placed buffer1 on the CPU and buffer2 on the GPU, then launched a GPU kernel to access buffer1. The access kernel took 13 seconds to complete. However, when I populated buffer2 on the CPU first and then moved it to the GPU, the access time was reduced to 6 seconds.
I am unsure why this discrepancy occurs.
#include <cstdio>
#include <cuda_runtime.h>
#include <iostream>
#include <unistd.h>
#include <chrono>
#define CUDA_CALL(func) { \
  cudaError_t status = func; \
  if (status != cudaSuccess) { \
    std::cerr << "CUDA API failed with error: " << cudaGetErrorString(status) << std::endl; \
    return 1; \
#define CALCULATE_TIME(func) { \
  cudaEvent_t start, stop; \
  cudaEventCreate(&start); \
  cudaEventCreate(&stop); \
  cudaEventRecord(start); \
  func; \
  cudaEventRecord(stop); \
  cudaEventSynchronize(stop); \
  float milliseconds = 0; \
  cudaEventElapsedTime(&milliseconds, start, stop); \
  std::cout << "Touch buffer time: " << milliseconds << "ms" << std::endl; \
// launch a kernel to touch the buffer concurrently
__global__ void populate_on_gpu(void* buffer, size_t size) {
  size_t* buffer_ptr = (size_t*)buffer;
  size_t buffer_size = size / sizeof(size_t);
  size_t tid = threadIdx.x + blockIdx.x * blockDim.x;
  size_t stride = blockDim.x * gridDim.x;
  for (size_t i = tid; i < buffer_size; i += stride) {
    buffer_ptr[i] = i;
void populate_on_cpu(void* buffer, size_t size) {
  for (size_t i = 0; i < buffer_size; i++) {
    buffer_ptr[i] = i;
int main() {
  // Set the GPU device to use
  cudaSetDevice(0);
  int deviceId;
  CUDA_CALL(cudaGetDevice(&deviceId));
  std::cout << "GPU Device ID: " << deviceId << std::endl;
  // Define the buffer size in bytes
  size_t bufferSize = 39ULL * 1024 * 1024 * 1024;
  // Allocate 40GB memory
  void* gpuBuffer1;
  CUDA_CALL(cudaMallocManaged(&gpuBuffer1, bufferSize, cudaMemAttachGlobal));
  // populate on GPU
  populate_on_gpu<<<4096, 512>>>(gpuBuffer1, bufferSize);
  // move to CPU
  populate_on_cpu(gpuBuffer1, bufferSize);
  CUDA_CALL(cudaDeviceSynchronize());
  // Allocate another 40GB memory
  void* gpuBuffer2;
  CUDA_CALL(cudaMallocManaged(&gpuBuffer2, bufferSize, cudaMemAttachGlobal));
  // populate on CPU
  // populate_on_cpu(gpuBuffer2, bufferSize);
  // populate on GPU
  populate_on_gpu<<<4096, 512>>>(gpuBuffer2, bufferSize);
  std::cout << "First touching buffer1: ";
  CALCULATE_TIME((populate_on_gpu<<<4096, 512>>>(gpuBuffer1, bufferSize)));
  std::cout << "Second touching buffer1: ";
  // Free the allocated memory
  cudaFree(gpuBuffer1);
  cudaFree(gpuBuffer2);
  return 0;
uncomment this line would boost the performance
I imagine it might be possible that the time to bring an allocation into physical existence and move it to the GPU might be quicker than the time to bring an allocation into physical existence on the GPU. Both will involve page-faulting. I imagine it might be possible that page-faulting for CPU pages might be quicker, perhaps a lot quicker, than page-faulting for GPU pages.
The profiler may shed light on it. nsight systems timeline can give you information about these types of activities.
I don’t know that my imaginings are correct, but if I wanted to start to understand it, I would probably start with a study on the profiler.
Thank you for your advice.
However, I’m unclear on why this relates to the page-faulting time of the CPU or GPU. I wonder if the line populate_on_cpu(gpuBuffer2, bufferSize) alters the eviction behavior of gpuBuffer2, but I’m not sure why that would be the case.
Additionally, I looked into the Nsight performance tool, and both programs exhibit similar activities.
