V100s crashe after 1 hour of load
Attaching bug report:
Seems to be power control issue?
Also when running diagnostic command using data center tool and set it to level 3 it crashes instantly
To whoever comes across the same issue D3 power management,
This seems to solve the issue, I ran the load again after the workaround for about 1 hour 20 minutes without issue
found here:
https://bbs.archlinux.org/viewtopic.php?id=297276
Update: only workaround for me now was to add line in
/etc/modprobe.d/nvidia.conf
options nvidia "NVreg_EnableGpuFirmware=0"
in order to disable GSP as seen here
You’ll need to:
sudo mkinitcpio -P
or for RHEL users
sudo dracut -f
and
sudo grub-mkconfig -o /boot/grub/grub.cfg
in my case it still shows
Video Memory Self Refresh: Not Supported
but it didnt crash
