Hi, there,
- stage: production (ready to deliver to our customer)
- environment: super node
- GPU: A100(40GB) x4
- CPU: 126 cores
- RAM: 480 GiB
- Parabricks: v3.8.0-ampere
- datasets
- the simplest fastq: R1 & R2
- WGS: R1 & R2 (44.48x)
We got stuck twice in the BWA program in the germline piepeline.
One case was for the simplest fastq (3 records each for R1 & R2, 150 bases per records)
Another case was for WGS (R1 & R2) (sequencing depth: 44.48x)
(We’ve run the germline pipeline for this WGS more than 20 times.)
The abnormal case like below:
[PB Info 2022-May-27 20:49:53] ------------------------------------------------------------------------------
[PB Info 2022-May-27 20:49:53] || Parabricks accelerated Genomics Pipeline ||
[PB Info 2022-May-27 20:49:53] || Version 3.8.0-1.ampere ||
[PB Info 2022-May-27 20:49:53] || GPU-BWA mem, Sorting Phase-I ||
[PB Info 2022-May-27 20:49:53] || Contact: Parabricks-Support@nvidia.com ||
(get stocks for a long time)
[M::bwa_idx_load_from_disk] read 0 ALT contigs
[PB Info 2022-May-27 20:49:56] GPU-BWA mem
[PB Info 2022-May-27 20:49:56] ProgressMeter Reads Base Pairs Aligned
[PB Info 2022-May-27 20:50:26] 5033176 770000000
[PB Info 2022-May-27 20:50:33] 10066352 1540000000
[PB Info 2022-May-27 20:50:40] 15099528 2290000000
[PB Info 2022-May-27 20:50:48] 20132704 3040000000
[PB Info 2022-May-27 20:50:55] 25165880 3790000000
The normal case is:
Are there any possible causes or clues to the symptom? (We’ve never met the abnormal case for non-ampere versions)
