Hello
I’m in the process of developing a camera driver and in the sample code I came across something that is called “fuse id”. Could someone explain me what this is and how I should be set? Currently, my camera driver fails during VI setup after it succesully read the fuse id over I2C:
[ 10.564448] imx185_fuse_id_setup, fuse id: 000000000000
[ 10.564496] vi vi: subdev imx185 7-001a bound
[ 10.564509] vi vi: notify complete, all subdevs registered
[ 10.564513] vi vi: creating links for entity imx185 7-001a
[ 10.564520] vi vi: processing endpoint /host1x/i2c@546c0000/tca9546@70/i2c@0/imx185_a@1a/ports/port@0/endpoint
[ 10.564561] vi vi: skipping channel port /host1x/i2c@546c0000/tca9546@70/i2c@0/imx185_a@1a:0
[ 10.564566] vi vi: creating links for channels
[ 10.564571] vi vi: processing endpoint /host1x/vi/ports/port@0/endpoint
[ 10.564591] vi vi: creating link for channel vi-output-0
[ 10.564597] vi vi: creating imx185 7-001a:0 -> vi-output-0:0 link
Unable to handle kernel NULL pointer dereference at virtual address 00000010
[ 10.574728] pgd = ffffffc0f3af4000
[ 10.579681] [00000010] *pgd=0000000000000000
I assume this error is related to the fuse id which I have not implemented in my camera firmware (the one running on my custom camera board) because I don’t know what it is and what it is needed for… Is it required at all?
