V4L2 capture jitter problem
I will apply this patch next week and provide you with the results. Thanks for the follow-up.
I’ve been able to try out this change. Note that I needed to add a parameter to get this to compile: “__flush_dcache_all(NULL);”.
This change induces a consistent 4ms delay across the capture period. I’ve taken one recording of a 10000 sample period (~20 minutes) and observed two instances where, in addition to the 4ms delay, there is a ~1ms jitter.
Thanks for your report.
Could you also help to try this patch.
From b1e5c1e716a33d317c9a82aa04eec76de46593df Mon Sep 17 00:00:00 2001
Date: Fri, 25 Sep 2020 00:11:56 +0530
Subject: [PATCH] DNI: arch: arm64: dma: use HW flush in place of invalidate/clean
Use tegra_flush_dcache_all which uses SCF to flush complete
cache hierarchy
Bug 200652069
Change-Id: I51df21f17eb42ee566f95fc5b886c9bcd9e1caed
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
diff --git a/arch/arm64/mm/dma-mapping.c b/arch/arm64/mm/dma-mapping.c
index 6ca1f43..b5e55ab 100644
--- a/arch/arm64/mm/dma-mapping.c
+++ b/arch/arm64/mm/dma-mapping.c
@@ -30,6 +30,7 @@
 #include <linux/vmalloc.h>
 #include <linux/swiotlb.h>
 #include <linux/pci.h>
+#include <linux/tegra-cache.h>
 #include <asm/cacheflush.h>
@@ -863,6 +864,7 @@
 				    struct scatterlist *sgl, int nelems,
 				    enum dma_data_direction dir)
+#if 0
 	struct scatterlist *sg;
 	int i;
@@ -872,12 +874,16 @@
 	for_each_sg(sgl, sg, nelems, i)
 		__dma_unmap_area_no_dsb(sg_virt(sg), sg->length, dir);
 	dsb(sy);
+#endif
+	void *unused = NULL;
+	tegra_flush_dcache_all(unused);
 static void __iommu_sync_sg_for_device(struct device *dev,
+#if 0
 	int i;
@@ -887,6 +893,9 @@
 		__dma_map_area_no_dsb(sg_virt(sg), sg->length, dir);
 	dsb(sy);
+#endif
 static int __iommu_map_sg_attrs(struct device *dev, struct scatterlist *sgl,
I needed to change the “#include” to reference tegra-mce.h as I don’t have a tegra-cache.h in my version of kernel. Running this, I see similar behavior – consistent 4ms delay overall and instances of 1ms jitter.
One other data point – I record buffer timestamp deltas (as frames are captured and are passed from VI → V4L2) and deltas as frames are passed to the application (V4L2 → application). With these DCACHE flush operations, I’m seeing the 1ms jitter appear in the frame capture buffer timestamps, as things are passed from VI → V4L2. This jitter is reflected in the V4L2 → application operations. Prior to these changes, the jitter was only detected in the V4L2 → application operation. I observed no jitter in the VI → V4L2 timestamp recording.
Here are plots of my captures for a frame of reference. I’m including the 1ms jitter observed with the DCACHE flushing operations, and then the 2ms jitter observed with the original dma-mapping.c file.
Y-axis in these plots is delta time between frames. We capture using a 10 fps trigger, so expectation is 100ms (100000us) between captures. X-axis is frame #.
The two following plots are the recorded deltas for a single 10000 frame capture period, using the DCACHE flush patches from above:
PLOT #1: V4L2 → application deltas
PLOT #2: VI → V4L2 timestamp deltas
The two following plots are the recorded deltas for a single 600 frame capture period, using the original dma-mapping.c implementation. Note that the V4L2 → application deltas do not coincide with the VI → V4L2 deltas, and the deltas in the latter are actually quite small (roughly +160us at worst.)
PLOT #3: V4L2 → application deltas
PLOT #4: VI → V4L2 timestamp deltas
So do you means, the delay worsens from ~2ms to ~4ms than the patch from V4L2 capture jitter problem - #23 by ShaneCCC
I’ve updated the plot post above and have numbered the plots from 1-4. Plots 1 & 2 show the DCACHE flush behavior. Plots 3 & 4 show the previous behavior.
Plots 3 & 4 show a consistent delta time of 100000us (which we’d expect at a 10fps capture rate). Plot 3 shows several “spikes”. Three of these are on the order of the 2ms jitter that caused me to write this post.
Plots 1 & 2 show a consistent delta time of 104000us – an extra 4ms appears which I presume is from the DCACHE flush. Plot 1 & 2 also show 4 instances of 1ms jitter.
An overall delay of 4ms is introduced by the DCACHE flush, and an additional 1ms jitter is observed on top of that.
I hope this is clear. If not, let me know and I’ll try to clarify further.
tegra_flush_dcache_all() shouldn’t be used for all sync requests. For smaller buffers, it wouldn’t be beneficial and increases the cache sync overhead significantly.
It should only be used when the buffer length is > few_mb. Could you start with buffer_length >= 1MB and check.
