V4l2-ctl can not capture raw data
Gstreamer can display camera video, but v4l2 can not capture raw data.
orin nano 8GB, r35.4.1
imx678 800w sensor
v4l2 cmd
v4l2-ctl -d /dev/video0 --set-fmt-video=width=3856,height=2176,pixelformat=RG12 --set-ctrl bypass_mode=0,gain=901,exposure=29999, --stream-mmap --stream-count=1 --stream-to=test.raw
[ 5771.817465] imx678 1-0010: sensor_power_on: power on
[ 5771.827723] bwmgr API not supported
[ 5771.828429] imx678 1-0010: imx678 set mode in 0!!!
[ 5772.033995] imx678 1-0010: sensor_set_gain:val:901 , gain: 3
[ 5772.034861] imx678 1-0010: sensor_set_exposure_shr:coarse_time is 2024,val is 29999, shs0 is 226, factor is 1000000 !!!1
[ 5772.036127] imx678 1-0010: sensor_start_streaming:
[ 5772.117101] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 1, flags: 0, err_data 64
[ 5772.150428] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 2, flags: 0, err_data 64
[ 5772.183755] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 3, flags: 0, err_data 64
[ 5772.217085] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 4, flags: 0, err_data 64
[ 5773.449707] imx678 1-0010: sensor_stop_streaming:
[ 5773.454872] bwmgr API not supported
[ 5773.455794] imx678 1-0010: sensor_power_off: power off
yt@yt-desktop:~$ v4l2-ctl -d /dev/video0 --set-fmt-video=width=3856,height=2176,pixelformat=RG12 --set-ctrl bypass_mode=0,gain=901,exposure=29999, --stream-mmap --stream-count=1 --stream-to=test.raw^C
yt@yt-desktop:~$ v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
        Type: Video Capture
        [0]: 'RG12' (12-bit Bayer RGRG/GBGB)
                Size: Discrete 3856x2176
                        Interval: Discrete 0.033s (30.000 fps)
                Size: Discrete 1928x1088
                Size: Discrete 3872x4508
Gstream cmd success display video
gst-launch-1.0 \
    nvarguscamerasrc sensor-id=0 \
    ! 'video/x-raw(memory:NVMM), width=3856, height=2176, format=(string)NV12, framerate=(fraction)30/1' \
    ! nvvidconv \
    ! 'video/x-raw,width=768, height=432' ! fpsdisplaysink text-overlay=1 video-sink=xvimagesink sync=0 -v
log
[ 6815.965150] imx678 1-0010: imx678 set mode in 0!!!
[ 6816.166610] imx678 1-0010: sensor_set_gain:val:901 , gain: 3
[ 6816.167447] imx678 1-0010: sensor_set_exposure_shr:coarse_time is 2024,val is 29999, shs0 is 226, factor is 1000000 !!!1
[ 6816.168709] imx678 1-0010: sensor_start_streaming:
[ 6816.173169] bwmgr API not supported
[ 6816.318751] bwmgr API not supported
[ 6816.450705] imx678 1-0010: sensor_set_gain:val:1201 , gain: 4
[ 6816.484036] imx678 1-0010: sensor_set_gain:val:1501 , gain: 5
[ 6816.517338] imx678 1-0010: sensor_set_gain:val:1801 , gain: 6
[ 6816.584002] imx678 1-0010: sensor_set_gain:val:2101 , gain: 7
[ 6816.650679] imx678 1-0010: sensor_set_gain:val:2401 , gain: 8
[ 6816.717386] imx678 1-0010: sensor_set_gain:val:2701 , gain: 9
[ 6816.750703] imx678 1-0010: sensor_set_gain:val:3001 , gain: 10
[ 6816.817323] imx678 1-0010: sensor_set_gain:val:3301 , gain: 11
[ 6816.884044] imx678 1-0010: sensor_set_gain:val:3601 , gain: 12
[ 6816.950655] imx678 1-0010: sensor_set_gain:val:3901 , gain: 13
[ 6817.017391] imx678 1-0010: sensor_set_gain:val:4201 , gain: 14
[ 6817.084033] imx678 1-0010: sensor_set_gain:val:4501 , gain: 15
[ 6817.150697] imx678 1-0010: sensor_set_gain:val:4801 , gain: 16
[ 6817.217383] imx678 1-0010: sensor_set_gain:val:5101 , gain: 17
[ 6817.317337] imx678 1-0010: sensor_set_gain:val:5401 , gain: 18
[ 6817.417354] imx678 1-0010: sensor_set_gain:val:5701 , gain: 19
[ 6817.517404] imx678 1-0010: sensor_set_gain:val:6001 , gain: 20
[ 6817.617321] imx678 1-0010: sensor_set_gain:val:6301 , gain: 21
[ 6817.784045] imx678 1-0010: sensor_set_gain:val:6601 , gain: 22
[ 6817.883999] imx678 1-0010: sensor_set_gain:val:7201 , gain: 24
[ 6818.582983] imx678 1-0010: sensor_stop_streaming:
[ 6818.587788] bwmgr API not supported
[ 6818.588319] imx678 1-0010: sensor_power_off: power off
How about below command. And get the trace log.
v4l2-ctl -d /dev/video0 --set-fmt-video=width=3856,height=2176,pixelformat=RG12 --set-ctrl bypass_mode=0, --stream-mmap
root@yt-desktop:/home/yt# cat /sys/kernel/debug/tracing/trace
tracer: nop
entries-in-buffer/entries-written: 272/272 #P:6
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
    v4l2-ctl-2814    [000] ....   265.412538: tegra_channel_open: vi-output, imx678 1-0010
    v4l2-ctl-2814    [000] ....   265.431055: tegra_channel_set_power: imx678 1-0010 : 0x1
    v4l2-ctl-2814    [000] ....   265.431071: camera_common_s_power: status : 0x1
    v4l2-ctl-2814    [000] ....   265.436246: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
    v4l2-ctl-2814    [000] ....   265.436249: csi_s_power: enable : 0x1
    v4l2-ctl-2814    [000] ....   265.436668: tegra_channel_capture_setup: vnc_id 0 W 3856 H 2176 fmt c4
    v4l2-ctl-2814    [000] ....   265.438125: tegra_channel_set_stream: enable : 0x1
    v4l2-ctl-2814    [000] ....   265.441531: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
    v4l2-ctl-2814    [000] ....   265.441533: csi_s_stream: enable : 0x1
    v4l2-ctl-2814    [000] ....   265.441920: tegra_channel_set_stream: imx678 1-0010 : 0x1
 kworker/1:4-374     [001] ....   265.466654: rtcpu_vinotify_event: tstamp:8810947119 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:281935054656 data:0x759e300010000000
 kworker/1:4-374     [001] ....   265.466656: rtcpu_vinotify_event: tstamp:8810947376 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:281935064352 data:0x0000000031000001
 kworker/1:4-374     [001] ....   265.466656: rtcpu_vinotify_event: tstamp:8810947658 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:281935147936 data:0x759e2d0010000000
 kworker/1:4-374     [001] ....   265.466657: rtcpu_vinotify_event: tstamp:8810947905 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:281935157856 data:0x0000000031000002
 kworker/1:4-374     [001] ....   265.746669: rtcpu_vinotify_event: tstamp:8819628416 cch:0 vi:1 tag:FS channel:0x00 frame:1 vi_tstamp:282225801376 data:0x0000000100000012
 kworker/1:4-374     [001] ....   265.746670: rtcpu_vinotify_event: tstamp:8819628675 cch:0 vi:1 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:282225801504 data:0x0000000800000000
 kworker/1:4-374     [001] ....   265.746670: rtcpu_vinotify_event: tstamp:8819628958 cch:0 vi:1 tag:CHANSEL_EMBED_SOF channel:0x23 frame:1 vi_tstamp:282225829888 data:0x0000000000000004
 kworker/1:4-374     [001] ....   265.746671: rtcpu_vinotify_event: tstamp:8819629199 cch:0 vi:1 tag:CHANSEL_EMBED_EOF channel:0x23 frame:1 vi_tstamp:282225839072 data:0x0000000000000008
 kworker/1:4-374     [001] ....   265.746671: rtcpu_vinotify_event: tstamp:8819629474 cch:0 vi:1 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:1 vi_tstamp:282225840256 data:0x0000000000000000
 kworker/1:4-374     [001] ....   265.746672: rtcpu_vinotify_event: tstamp:8819629715 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:1 vi_tstamp:282225865440 data:0x0000000003020001
 kworker/1:4-374     [001] ....   265.746672: rtcpu_vinotify_event: tstamp:8819629992 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:1 vi_tstamp:282225844768 data:0x00000000000006e9
 kworker/1:4-374     [001] ....   265.746673: rtcpu_vinotify_event: tstamp:8819630239 cch:0 vi:1 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:282226141088 data:0x0000000000000001
 kworker/1:4-374     [001] ....   265.746673: rtcpu_vinotify_event: tstamp:8819630515 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:1 vi_tstamp:282226151904 data:0x0000000008020001
 kworker/1:4-374     [001] ....   265.804793: rtcpu_vinotify_event: tstamp:8820586126 cch:0 vi:1 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:282258371808 data:0x00000000087f0002
 kworker/1:4-374     [001] ....   265.804794: rtcpu_vinotify_event: tstamp:8820586419 cch:0 vi:1 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:282258373056 data:0x0000000000000000
 kworker/1:4-374     [001] ....   265.804794: rtcpu_vinotify_event: tstamp:8820586672 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:1 vi_tstamp:282258395456 data:0x0000000002020001
 kworker/1:4-374     [001] ....   265.804795: rtcpu_vinotify_event: tstamp:8821093089 cch:0 vi:1 tag:CHANSEL_FAULT channel:0x23 frame:1 vi_tstamp:282258377440 data:0x0000000008800040
 kworker/1:4-374     [001] ....   265.804795: rtcpu_vinotify_event: tstamp:8821093342 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:1 vi_tstamp:282258460416 data:0x0000000001020001
 kworker/1:4-374     [001] ....   265.804795: rtcpu_vinotify_event: tstamp:8821093624 cch:0 vi:1 tag:FE channel:0x00 frame:1 vi_tstamp:282258431712 data:0x0000000100000022
 kworker/1:4-374     [001] ....   265.804796: rtcpu_vinotify_event: tstamp:8821093880 cch:0 vi:1 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:282258431776 data:0x0000000800000000
 kworker/1:4-374     [001] ....   265.804796: rtcpu_vinotify_event: tstamp:8821094163 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:282258836480 data:0x759e300010000000
 kworker/1:4-374     [001] ....   265.804796: rtcpu_vinotify_event: tstamp:8821094411 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:282258879776 data:0x0000000031000003
 kworker/1:4-374     [001] ....   265.804797: rtcpu_vinotify_event: tstamp:8821094688 cch:0 vi:1 tag:FS channel:0x00 frame:2 vi_tstamp:282259133632 data:0x0000000200000012
 kworker/1:4-374     [001] ....   265.804797: rtcpu_vinotify_event: tstamp:8821094945 cch:0 vi:1 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:282259133696 data:0x0000000800000000
 kworker/1:4-374     [001] ....   265.804797: rtcpu_vinotify_event: tstamp:8821095226 cch:0 vi:1 tag:CHANSEL_EMBED_SOF channel:0x23 frame:2 vi_tstamp:282259162496 data:0x0000000000000004
 kworker/1:4-374     [001] ....   265.804798: rtcpu_vinotify_event: tstamp:8821095471 cch:0 vi:1 tag:CHANSEL_EMBED_EOF channel:0x23 frame:2 vi_tstamp:282259171712 data:0x0000000000000008
 kworker/1:4-374     [001] ....   265.804798: rtcpu_vinotify_event: tstamp:8821095750 cch:0 vi:1 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:2 vi_tstamp:282259172896 data:0x0000000000000000
 kworker/1:4-374     [001] ....   265.804798: rtcpu_vinotify_event: tstamp:8821095994 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:2 vi_tstamp:282259197760 data:0x0000000003020002
 kworker/1:4-374     [001] ....   265.804799: rtcpu_vinotify_event: tstamp:8821096275 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:2 vi_tstamp:282259177376 data:0x00000000000006e9
 kworker/1:4-374     [001] ....   265.804799: rtcpu_vinotify_event: tstamp:8821096519 cch:0 vi:1 tag:CHANSEL_PXL_SOF channel:0x23 frame:2 vi_tstamp:282259473696 data:0x0000000000000001
 kworker/1:4-374     [001] ....   265.804799: rtcpu_vinotify_event: tstamp:8821096791 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:2 vi_tstamp:282259484576 data:0x0000000008020002
 kworker/1:4-374     [001] ....   265.804800: rtcpu_vinotify_event: tstamp:8821627686 cch:0 vi:1 tag:CHANSEL_PXL_EOF channel:0x23 frame:2 vi_tstamp:282291704416 data:0x00000000087f0002
 kworker/1:4-374     [001] ....   265.804800: rtcpu_vinotify_event: tstamp:8821656694 cch:0 vi:1 tag:ATOMP_FRAME_DONE channel:0x23 frame:2 vi_tstamp:282291705664 data:0x0000000000000000
 kworker/1:4-374     [001] ....   265.804801: rtcpu_vinotify_event: tstamp:8821656950 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:2 vi_tstamp:282291740416 data:0x0000000002020002
 kworker/1:4-374     [001] ....   265.804801: rtcpu_vinotify_event: tstamp:8821657231 cch:0 vi:1 tag:CHANSEL_FAULT channel:0x23 frame:2 vi_tstamp:282291710048 data:0x0000000008800040
 kworker/1:4-374     [001] ....   265.804801: rtcpu_vinotify_event: tstamp:8821657476 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:2 vi_tstamp:282291801600 data:0x0000000001020002
 kworker/1:4-374     [001] ....   265.804802: rtcpu_vinotify_event: tstamp:8821657750 cch:0 vi:1 tag:FE channel:0x00 frame:2 vi_tstamp:282291764320 data:0x0000000200000022
 kworker/1:4-374     [001] ....   265.804802: rtcpu_vinotify_event: tstamp:8821658005 cch:0 vi:1 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:282291764416 data:0x0000000800000000
 kworker/1:4-374     [001] ....   265.804802: rtcpu_vinotify_event: tstamp:8821658281 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:282292147680 data:0x759e2d0010000000
 kworker/1:4-374     [001] ....   265.804803: rtcpu_vinotify_event: tstamp:8821658524 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:282292195648 data:0x0000000031000004
 kworker/1:4-374     [001] ....   265.804803: rtcpu_vinotify_event: tstamp:8821658797 cch:0 vi:1 tag:FS channel:0x00 frame:3 vi_tstamp:282292466208 data:0x0000000300000012
 kworker/1:4-374     [001] ....   265.804803: rtcpu_vinotify_event: tstamp:8821659051 cch:0 vi:1 tag:ATOMP_FS channel:0x00 frame:3 vi_tstamp:282292466304 data:0x0000000800000000
 kworker/1:4-374     [001] ....   265.804804: rtcpu_vinotify_event: tstamp:8821659330 cch:0 vi:1 tag:CHANSEL_EMBED_SOF channel:0x23 frame:3 vi_tstamp:282292495136 data:0x0000000000000004
 kworker/1:4-374     [001] ....   265.804804: rtcpu_vinotify_event: tstamp:8821659575 cch:0 vi:1 tag:CHANSEL_EMBED_EOF channel:0x23 frame:3 vi_tstamp:282292504288 data:0x0000000000000008
 kworker/1:4-374     [001] ....   265.804804: rtcpu_vinotify_event: tstamp:8821659851 cch:0 vi:1 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:3 vi_tstamp:282292505472 data:0x0000000000000000
 kworker/1:4-374     [001] ....   265.804805: rtcpu_vinotify_event: tstamp:8821660098 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:282292530336 data:0x0000000003020003
 kworker/1:4-374     [001] ....   265.804805: rtcpu_vinotify_event: tstamp:8821660379 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:3 vi_tstamp:282292510016 data:0x00000000000006e9
 kworker/1:4-374     [001] ....   265.804806: rtcpu_vinotify_event: tstamp:8821660624 cch:0 vi:1 tag:CHANSEL_PXL_SOF channel:0x23 frame:3 vi_tstamp:282292806304 data:0x0000000000000001
 kworker/1:4-374     [001] ....   265.858660: rtcpu_vinotify_event: tstamp:8822178110 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:282292825344 data:0x0000000008020003
 kworker/1:4-374     [001] ....   265.858660: rtcpu_vinotify_event: tstamp:8822698355 cch:0 vi:1 tag:CHANSEL_PXL_EOF channel:0x23 frame:3 vi_tstamp:282325037024 data:0x00000000087f0002
 kworker/1:4-374     [001] ....   265.858661: rtcpu_vinotify_event: tstamp:8822698640 cch:0 vi:1 tag:ATOMP_FRAME_DONE channel:0x23 frame:3 vi_tstamp:282325038272 data:0x0000000000000000
 kworker/1:4-374     [001] ....   265.858661: rtcpu_vinotify_event: tstamp:8822698891 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:282325060576 data:0x0000000002020003
 kworker/1:4-374     [001] ....   265.858661: rtcpu_vinotify_event: tstamp:8822699173 cch:0 vi:1 tag:CHANSEL_FAULT channel:0x23 frame:3 vi_tstamp:282325042624 data:0x0000000008800040
 kworker/1:4-374     [001] ....   265.858661: rtcpu_vinotify_event: tstamp:8822699422 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:282325112928 data:0x0000000001020003
 kworker/1:4-374     [001] ....   265.858662: rtcpu_vinotify_event: tstamp:8822699706 cch:0 vi:1 tag:FE channel:0x00 frame:3 vi_tstamp:282325096928 data:0x0000000300000022
 kworker/1:4-374     [001] ....   265.858662: rtcpu_vinotify_event: tstamp:8822699962 cch:0 vi:1 tag:ATOMP_FE channel:0x00 frame:3 vi_tstamp:282325097024 data:0x0000000800000000
 kworker/1:4-374     [001] ....   265.858662: rtcpu_vinotify_event: tstamp:8822700256 cch:0 vi:1 tag:FS channel:0x00 frame:4 vi_tstamp:282325798848 data:0x0000000400000012
 kworker/1:4-374     [001] ....   265.858662: rtcpu_vinotify_event: tstamp:8822700509 cch:0 vi:1 tag:ATOMP_FS channel:0x00 frame:4 vi_tstamp:282325798944 data:0x0000000800000000
 kworker/1:4-374     [001] ....   265.858663: rtcpu_vinotify_event: tstamp:8822700846 cch:0 vi:1 tag:CHANSEL_EMBED_SOF channel:0x23 frame:4 vi_tstamp:282325827744 data:0x0000000000000004
 kworker/1:4-374     [001] ....   265.858663: rtcpu_vinotify_event: tstamp:8822701091 cch:0 vi:1 tag:CHANSEL_EMBED_EOF channel:0x23 frame:4 vi_tstamp:282325836928 data:0x0000000000000008
 kworker/1:4-374     [001] ....   265.858663: rtcpu_vinotify_event: tstamp:8822701369 cch:0 vi:1 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:4 vi_tstamp:282325838112 data:0x0000000000000000
 kworker/1:4-374     [001] ....   265.858663: rtcpu_vinotify_event: tstamp:8822701616 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:282325862976 data:0x0000000003020004
 kworker/1:4-374     [001] ....   265.858664: rtcpu_vinotify_event: tstamp:8822701896 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:4 vi_tstamp:282325842624 data:0x00000000000006e9
 kworker/1:4-374     [001] ....   265.858664: rtcpu_vinotify_event: tstamp:8822702143 cch:0 vi:1 tag:CHANSEL_PXL_SOF channel:0x23 frame:4 vi_tstamp:282326138944 data:0x0000000000000001
 kworker/1:4-374     [001] ....   265.858664: rtcpu_vinotify_event: tstamp:8823208669 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:282326157984 data:0x0000000008020004
 kworker/1:4-374     [001] ....   265.914663: rtcpu_vinotify_error: tstamp:8823728034 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:5 vi_tstamp:282359160352 data:0x0000000000000249
 kworker/1:4-374     [001] ....   265.914663: rtcpu_vinotify_event: tstamp:8823750912 cch:0 vi:1 tag:CHANSEL_PXL_EOF channel:0x23 frame:4 vi_tstamp:282358369632 data:0x00000000087f0002
 kworker/1:4-374     [001] ....   265.914664: rtcpu_vinotify_event: tstamp:8823751196 cch:0 vi:1 tag:ATOMP_FRAME_DONE channel:0x23 frame:4 vi_tstamp:282358370880 data:0x0000000000000000
 kworker/1:4-374     [001] ....   265.914664: rtcpu_vinotify_event: tstamp:8823751445 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:282358393184 data:0x0000000002020004
 kworker/1:4-374     [001] ....   265.914664: rtcpu_vinotify_event: tstamp:8823751726 cch:0 vi:1 tag:CHANSEL_FAULT channel:0x23 frame:4 vi_tstamp:282358375264 data:0x0000000008800040
 kworker/1:4-374     [001] ....   265.914664: rtcpu_vinotify_event: tstamp:8823751977 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:282358445536 data:0x0000000001020004
 kworker/1:4-374     [001] ....   265.914665: rtcpu_vinotify_event: tstamp:8823752258 cch:0 vi:1 tag:FE channel:0x00 frame:4 vi_tstamp:282358429568 data:0x0000000400000022
 kworker/1:4-374     [001] ....   265.914665: rtcpu_vinotify_event: tstamp:8823752516 cch:0 vi:1 tag:ATOMP_FE channel:0x00 frame:4 vi_tstamp:282358429632 data:0x0000000800000000
 kworker/1:4-374     [001] ....   265.914665: rtcpu_vinotify_event: tstamp:8823752792 cch:0 vi:1 tag:FS channel:0x00 frame:5 vi_tstamp:282359131456 data:0x0000000500000012
 kworker/1:4-374     [001] ....   265.914665: rtcpu_vinotify_event: tstamp:8823753037 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:5 vi_tstamp:282359160352 data:0x0000000000000249
 kworker/1:4-374     [001] ....   265.914665: rtcpu_vinotify_error: tstamp:8824769679 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:6 vi_tstamp:282392492960 data:0x0000000000000249
 kworker/1:4-374     [001] ....   265.914666: rtcpu_vinotify_event: tstamp:8824836275 cch:0 vi:1 tag:FE channel:0x00 frame:5 vi_tstamp:282391762208 data:0x0000000500000022
 kworker/1:4-374     [001] ....   265.914666: rtcpu_vinotify_event: tstamp:8824836520 cch:0 vi:1 tag:FS channel:0x00 frame:6 vi_tstamp:282392464064 data:0x0000000600000012
 kworker/1:4-374     [001] ....   265.914668: rtcpu_vinotify_event: tstamp:8824836808 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:6 vi_tstamp:282392492960 data:0x0000000000000249
 kworker/1:4-374     [001] ....   265.970657: rtcpu_vinotify_error: tstamp:8825811507 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:7 vi_tstamp:282425825568 data:0x0000000000000249
 kworker/1:4-374     [001] ....   265.970658: rtcpu_vinotify_event: tstamp:8825812612 cch:0 vi:1 tag:FE channel:0x00 frame:6 vi_tstamp:282425094784 data:0x0000000600000022
 kworker/1:4-374     [001] ....   265.970658: rtcpu_vinotify_event: tstamp:8825812892 cch:0 vi:1 tag:FS channel:0x00 frame:7 vi_tstamp:282425796704 data:0x0000000700000012
 kworker/1:4-374     [001] ....   265.970658: rtcpu_vinotify_event: tstamp:8825813136 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:7 vi_tstamp:282425825568 data:0x0000000000000249
 kworker/1:4-374     [001] ....   265.970658: rtcpu_vinotify_event: tstamp:8826843834 cch:0 vi:1 tag:FE channel:0x00 frame:7 vi_tstamp:282458427392 data:0x0000000700000022
 kworker/1:4-374     [001] ....   265.970659: rtcpu_vinotify_error: tstamp:8826852965 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:8 vi_tstamp:282459158176 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.026663: rtcpu_vinotify_event: tstamp:8827386257 cch:0 vi:1 tag:FS channel:0x00 frame:8 vi_tstamp:282459129312 data:0x0000000800000012
 kworker/1:4-374     [001] ....   266.026663: rtcpu_vinotify_event: tstamp:8827386541 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:8 vi_tstamp:282459158176 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.026664: rtcpu_vinotify_error: tstamp:8827894614 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:9 vi_tstamp:282492490816 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.026664: rtcpu_vinotify_event: tstamp:8827928988 cch:0 vi:1 tag:FE channel:0x00 frame:8 vi_tstamp:282491760032 data:0x0000000800000022
 kworker/1:4-374     [001] ....   266.026665: rtcpu_vinotify_event: tstamp:8827929269 cch:0 vi:1 tag:FS channel:0x00 frame:9 vi_tstamp:282492461920 data:0x0000000900000012
 kworker/1:4-374     [001] ....   266.026665: rtcpu_vinotify_event: tstamp:8827929512 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:9 vi_tstamp:282492490816 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.082662: rtcpu_vinotify_error: tstamp:8828936257 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:10 vi_tstamp:282525823456 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.082663: rtcpu_vinotify_event: tstamp:8829014404 cch:0 vi:1 tag:FE channel:0x00 frame:9 vi_tstamp:282525092672 data:0x0000000900000022
 kworker/1:4-374     [001] ....   266.082664: rtcpu_vinotify_event: tstamp:8829014652 cch:0 vi:1 tag:FS channel:0x00 frame:10 vi_tstamp:282525794560 data:0x0000000a00000012
 kworker/1:4-374     [001] ....   266.082664: rtcpu_vinotify_event: tstamp:8829014944 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:10 vi_tstamp:282525823456 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.082665: rtcpu_vinotify_error: tstamp:8829977893 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:11 vi_tstamp:282559156064 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.082665: rtcpu_vinotify_event: tstamp:8830098578 cch:0 vi:1 tag:FE channel:0x00 frame:10 vi_tstamp:282558425280 data:0x0000000a00000022
 kworker/1:4-374     [001] ....   266.082666: rtcpu_vinotify_event: tstamp:8830098858 cch:0 vi:1 tag:FS channel:0x00 frame:11 vi_tstamp:282559127168 data:0x0000000b00000012
 kworker/1:4-374     [001] ....   266.082666: rtcpu_vinotify_event: tstamp:8830099101 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:11 vi_tstamp:282559156064 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.138723: rtcpu_vinotify_error: tstamp:8831019540 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:12 vi_tstamp:282592488704 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.138724: rtcpu_vinotify_event: tstamp:8831183932 cch:0 vi:1 tag:FE channel:0x00 frame:11 vi_tstamp:282591757856 data:0x0000000b00000022
 kworker/1:4-374     [001] ....   266.138724: rtcpu_vinotify_event: tstamp:8831184180 cch:0 vi:1 tag:FS channel:0x00 frame:12 vi_tstamp:282592459776 data:0x0000000c00000012
 kworker/1:4-374     [001] ....   266.138725: rtcpu_vinotify_event: tstamp:8831184461 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:12 vi_tstamp:282592488704 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.138725: rtcpu_vinotify_event: tstamp:8832037346 cch:0 vi:1 tag:FE channel:0x00 frame:12 vi_tstamp:282625090528 data:0x0000000c00000022
 kworker/1:4-374     [001] ....   266.138726: rtcpu_vinotify_error: tstamp:8832061177 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:13 vi_tstamp:282625821280 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.194661: rtcpu_vinotify_event: tstamp:8832540286 cch:0 vi:1 tag:FS channel:0x00 frame:13 vi_tstamp:282625792416 data:0x0000000d00000012
 kworker/1:4-374     [001] ....   266.194661: rtcpu_vinotify_event: tstamp:8832540535 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:13 vi_tstamp:282625821280 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.194662: rtcpu_vinotify_event: tstamp:8833083202 cch:0 vi:1 tag:FE channel:0x00 frame:13 vi_tstamp:282658423104 data:0x0000000d00000022
 kworker/1:4-374     [001] ....   266.194663: rtcpu_vinotify_error: tstamp:8833102822 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:14 vi_tstamp:282659153952 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.194663: rtcpu_vinotify_event: tstamp:8833625645 cch:0 vi:1 tag:FS channel:0x00 frame:14 vi_tstamp:282659125024 data:0x0000000e00000012
 kworker/1:4-374     [001] ....   266.194664: rtcpu_vinotify_event: tstamp:8833625925 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:14 vi_tstamp:282659153952 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.250663: rtcpu_vinotify_error: tstamp:8834144473 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:15 vi_tstamp:282692486528 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.250663: rtcpu_vinotify_event: tstamp:8834168355 cch:0 vi:1 tag:FE channel:0x00 frame:14 vi_tstamp:282691755744 data:0x0000000e00000022
 kworker/1:4-374     [001] ....   266.250664: rtcpu_vinotify_event: tstamp:8834168633 cch:0 vi:1 tag:FS channel:0x00 frame:15 vi_tstamp:282692457632 data:0x0000000f00000012
 kworker/1:4-374     [001] ....   266.250664: rtcpu_vinotify_event: tstamp:8834168875 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:15 vi_tstamp:282692486528 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.250665: rtcpu_vinotify_error: tstamp:8835186113 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:16 vi_tstamp:282725819136 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.250665: rtcpu_vinotify_event: tstamp:8835252613 cch:0 vi:1 tag:FE channel:0x00 frame:15 vi_tstamp:282725088352 data:0x0000000f00000022
 kworker/1:4-374     [001] ....   266.250666: rtcpu_vinotify_event: tstamp:8835252858 cch:0 vi:1 tag:FS channel:0x00 frame:16 vi_tstamp:282725790272 data:0x0000001000000012
 kworker/1:4-374     [001] ....   266.250666: rtcpu_vinotify_event: tstamp:8835253141 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:16 vi_tstamp:282725819136 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.306663: rtcpu_vinotify_error: tstamp:8836227755 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:17 vi_tstamp:282759151744 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.306663: rtcpu_vinotify_event: tstamp:8836337980 cch:0 vi:1 tag:FE channel:0x00 frame:16 vi_tstamp:282758420992 data:0x0000001000000022
 kworker/1:4-374     [001] ....   266.306664: rtcpu_vinotify_event: tstamp:8836338259 cch:0 vi:1 tag:FS channel:0x00 frame:17 vi_tstamp:282759122912 data:0x0000001100000012
 kworker/1:4-374     [001] ....   266.306664: rtcpu_vinotify_event: tstamp:8836338500 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:17 vi_tstamp:282759151744 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.306664: rtcpu_vinotify_error: tstamp:8837271059 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:18 vi_tstamp:282792484384 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.306664: rtcpu_vinotify_event: tstamp:8837272088 cch:0 vi:1 tag:FE channel:0x00 frame:17 vi_tstamp:282791753600 data:0x0000001100000022
 kworker/1:4-374     [001] ....   266.306664: rtcpu_vinotify_event: tstamp:8837272336 cch:0 vi:1 tag:FS channel:0x00 frame:18 vi_tstamp:282792455488 data:0x0000001200000012
 kworker/1:4-374     [001] ....   266.362664: rtcpu_vinotify_event: tstamp:8837802783 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:18 vi_tstamp:282792484384 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.362665: rtcpu_vinotify_error: tstamp:8838311046 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:19 vi_tstamp:282825816992 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.362666: rtcpu_vinotify_event: tstamp:8838345487 cch:0 vi:1 tag:FE channel:0x00 frame:18 vi_tstamp:282825086240 data:0x0000001200000022
 kworker/1:4-374     [001] ....   266.362666: rtcpu_vinotify_event: tstamp:8838345771 cch:0 vi:1 tag:FS channel:0x00 frame:19 vi_tstamp:282825788128 data:0x0000001300000012
 kworker/1:4-374     [001] ....   266.362667: rtcpu_vinotify_event: tstamp:8838346018 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:19 vi_tstamp:282825816992 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.362667: rtcpu_vinotify_error: tstamp:8839352695 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:20 vi_tstamp:282859149600 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.418661: rtcpu_vinotify_event: tstamp:8839430860 cch:0 vi:1 tag:FE channel:0x00 frame:19 vi_tstamp:282858418848 data:0x0000001300000022
 kworker/1:4-374     [001] ....   266.418662: rtcpu_vinotify_event: tstamp:8839431111 cch:0 vi:1 tag:FS channel:0x00 frame:20 vi_tstamp:282859120736 data:0x0000001400000012
 kworker/1:4-374     [001] ....   266.418662: rtcpu_vinotify_event: tstamp:8839431395 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:20 vi_tstamp:282859149600 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.418662: rtcpu_vinotify_error: tstamp:8840394339 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:21 vi_tstamp:282892482208 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.418662: rtcpu_vinotify_event: tstamp:8840516192 cch:0 vi:1 tag:FE channel:0x00 frame:20 vi_tstamp:282891751456 data:0x0000001400000022
 kworker/1:4-374     [001] ....   266.418663: rtcpu_vinotify_event: tstamp:8840516471 cch:0 vi:1 tag:FS channel:0x00 frame:21 vi_tstamp:282892453344 data:0x0000001500000012
 kworker/1:4-374     [001] ....   266.418663: rtcpu_vinotify_event: tstamp:8840516712 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:21 vi_tstamp:282892482208 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.474664: rtcpu_vinotify_error: tstamp:8841435978 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:22 vi_tstamp:282925814848 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.474665: rtcpu_vinotify_event: tstamp:8841600436 cch:0 vi:1 tag:FE channel:0x00 frame:21 vi_tstamp:282925084064 data:0x0000001500000022
 kworker/1:4-374     [001] ....   266.474665: rtcpu_vinotify_event: tstamp:8841600684 cch:0 vi:1 tag:FS channel:0x00 frame:22 vi_tstamp:282925785984 data:0x0000001600000012
 kworker/1:4-374     [001] ....   266.474665: rtcpu_vinotify_event: tstamp:8841600965 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:22 vi_tstamp:282925814848 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.474665: rtcpu_vinotify_error: tstamp:8842477804 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:23 vi_tstamp:282959147488 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.474666: rtcpu_vinotify_event: tstamp:8842478897 cch:0 vi:1 tag:FE channel:0x00 frame:22 vi_tstamp:282958416672 data:0x0000001600000022
 kworker/1:4-374     [001] ....   266.474666: rtcpu_vinotify_event: tstamp:8842479172 cch:0 vi:1 tag:FS channel:0x00 frame:23 vi_tstamp:282959118560 data:0x0000001700000012
 kworker/1:4-374     [001] ....   266.474666: rtcpu_vinotify_event: tstamp:8842479412 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:23 vi_tstamp:282959147488 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.530683: rtcpu_vinotify_event: tstamp:8843499385 cch:0 vi:1 tag:FE channel:0x00 frame:23 vi_tstamp:282991749280 data:0x0000001700000022
 kworker/1:4-374     [001] ....   266.530683: rtcpu_vinotify_error: tstamp:8843519260 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:24 vi_tstamp:282992480096 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.530684: rtcpu_vinotify_event: tstamp:8844041820 cch:0 vi:1 tag:FS channel:0x00 frame:24 vi_tstamp:282992451200 data:0x0000001800000012
 kworker/1:4-374     [001] ....   266.530684: rtcpu_vinotify_event: tstamp:8844042104 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:24 vi_tstamp:282992480096 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.530684: rtcpu_vinotify_error: tstamp:8844560913 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:25 vi_tstamp:283025812704 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.530685: rtcpu_vinotify_event: tstamp:8844584544 cch:0 vi:1 tag:FE channel:0x00 frame:24 vi_tstamp:283025081920 data:0x0000001800000022
 kworker/1:4-374     [001] ....   266.530685: rtcpu_vinotify_event: tstamp:8844584824 cch:0 vi:1 tag:FS channel:0x00 frame:25 vi_tstamp:283025783808 data:0x0000001900000012
 kworker/1:4-374     [001] ....   266.530686: rtcpu_vinotify_event: tstamp:8844585067 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:25 vi_tstamp:283025812704 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.586666: rtcpu_vinotify_error: tstamp:8845602560 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:26 vi_tstamp:283059145312 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.586668: rtcpu_vinotify_event: tstamp:8845669977 cch:0 vi:1 tag:FE channel:0x00 frame:25 vi_tstamp:283058414528 data:0x0000001900000022
 kworker/1:4-374     [001] ....   266.586668: rtcpu_vinotify_event: tstamp:8845670225 cch:0 vi:1 tag:FS channel:0x00 frame:26 vi_tstamp:283059116448 data:0x0000001a00000012
 kworker/1:4-374     [001] ....   266.586669: rtcpu_vinotify_event: tstamp:8845670508 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:26 vi_tstamp:283059145312 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.642667: rtcpu_vinotify_error: tstamp:8846644203 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:27 vi_tstamp:283092477952 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.642668: rtcpu_vinotify_event: tstamp:8846755250 cch:0 vi:1 tag:FE channel:0x00 frame:26 vi_tstamp:283091747136 data:0x0000001a00000022
 kworker/1:4-374     [001] ....   266.642669: rtcpu_vinotify_event: tstamp:8846755532 cch:0 vi:1 tag:FS channel:0x00 frame:27 vi_tstamp:283092449056 data:0x0000001b00000012
 kworker/1:4-374     [001] ....   266.642669: rtcpu_vinotify_event: tstamp:8846755777 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:27 vi_tstamp:283092477952 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.642669: rtcpu_vinotify_error: tstamp:8847685846 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:28 vi_tstamp:283125810560 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.642670: rtcpu_vinotify_event: tstamp:8847839492 cch:0 vi:1 tag:FE channel:0x00 frame:27 vi_tstamp:283125079776 data:0x0000001b00000022
 kworker/1:4-374     [001] ....   266.642670: rtcpu_vinotify_event: tstamp:8847839741 cch:0 vi:1 tag:FS channel:0x00 frame:28 vi_tstamp:283125781664 data:0x0000001c00000012
 kworker/1:4-374     [001] ....   266.642670: rtcpu_vinotify_event: tstamp:8847840025 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:28 vi_tstamp:283125810560 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.698667: rtcpu_vinotify_event: tstamp:8848703745 cch:0 vi:1 tag:FE channel:0x00 frame:28 vi_tstamp:283158412416 data:0x0000001c00000022
 kworker/1:4-374     [001] ....   266.698668: rtcpu_vinotify_error: tstamp:8848727489 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:29 vi_tstamp:283159143168 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.698669: rtcpu_vinotify_event: tstamp:8849195842 cch:0 vi:1 tag:FS channel:0x00 frame:29 vi_tstamp:283159114304 data:0x0000001d00000012
 kworker/1:4-374     [001] ....   266.698669: rtcpu_vinotify_event: tstamp:8849196091 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:29 vi_tstamp:283159143168 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.698669: rtcpu_vinotify_error: tstamp:8849769129 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:30 vi_tstamp:283192475776 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.754667: rtcpu_vinotify_event: tstamp:8850281200 cch:0 vi:1 tag:FE channel:0x00 frame:29 vi_tstamp:283191744992 data:0x0000001d00000022
 kworker/1:4-374     [001] ....   266.754668: rtcpu_vinotify_event: tstamp:8850281452 cch:0 vi:1 tag:FS channel:0x00 frame:30 vi_tstamp:283192446912 data:0x0000001e00000012
 kworker/1:4-374     [001] ....   266.754668: rtcpu_vinotify_event: tstamp:8850281734 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:30 vi_tstamp:283192475776 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.754669: rtcpu_vinotify_error: tstamp:8850810783 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:31 vi_tstamp:283225808416 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.754669: rtcpu_vinotify_event: tstamp:8850823906 cch:0 vi:1 tag:FE channel:0x00 frame:30 vi_tstamp:283225077600 data:0x0000001e00000022
 kworker/1:4-374     [001] ....   266.754670: rtcpu_vinotify_event: tstamp:8850824181 cch:0 vi:1 tag:FS channel:0x00 frame:31 vi_tstamp:283225779552 data:0x0000001f00000012
 kworker/1:4-374     [001] ....   266.754670: rtcpu_vinotify_event: tstamp:8850824421 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:31 vi_tstamp:283225808416 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.810670: rtcpu_vinotify_error: tstamp:8851852424 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:32 vi_tstamp:283259141024 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.810671: rtcpu_vinotify_event: tstamp:8851909263 cch:0 vi:1 tag:FE channel:0x00 frame:31 vi_tstamp:283258410240 data:0x0000001f00000022
 kworker/1:4-374     [001] ....   266.810671: rtcpu_vinotify_event: tstamp:8851909512 cch:0 vi:1 tag:FS channel:0x00 frame:32 vi_tstamp:283259112128 data:0x0000002000000012
 kworker/1:4-374     [001] ....   266.810671: rtcpu_vinotify_event: tstamp:8851909796 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:32 vi_tstamp:283259141024 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.810671: rtcpu_vinotify_error: tstamp:8852894072 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:33 vi_tstamp:283292473632 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.810672: rtcpu_vinotify_event: tstamp:8852994653 cch:0 vi:1 tag:FE channel:0x00 frame:32 vi_tstamp:283291742880 data:0x0000002000000022
 kworker/1:4-374     [001] ....   266.810672: rtcpu_vinotify_event: tstamp:8852994932 cch:0 vi:1 tag:FS channel:0x00 frame:33 vi_tstamp:283292444768 data:0x0000002100000012
 kworker/1:4-374     [001] ....   266.810672: rtcpu_vinotify_event: tstamp:8852995174 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:33 vi_tstamp:283292473632 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.866669: rtcpu_vinotify_error: tstamp:8853937366 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:34 vi_tstamp:283325806272 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.866670: rtcpu_vinotify_event: tstamp:8853938394 cch:0 vi:1 tag:FE channel:0x00 frame:33 vi_tstamp:283325075488 data:0x0000002100000022
 kworker/1:4-374     [001] ....   266.866670: rtcpu_vinotify_event: tstamp:8853938639 cch:0 vi:1 tag:FS channel:0x00 frame:34 vi_tstamp:283325777376 data:0x0000002200000012
 kworker/1:4-374     [001] ....   266.866670: rtcpu_vinotify_event: tstamp:8854459426 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:34 vi_tstamp:283325806272 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.866671: rtcpu_vinotify_error: tstamp:8854977350 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:35 vi_tstamp:283359138880 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.866671: rtcpu_vinotify_event: tstamp:8855001035 cch:0 vi:1 tag:FE channel:0x00 frame:34 vi_tstamp:283358408096 data:0x0000002200000022
 kworker/1:4-374     [001] ....   266.866671: rtcpu_vinotify_event: tstamp:8855001314 cch:0 vi:1 tag:FS channel:0x00 frame:35 vi_tstamp:283359109984 data:0x0000002300000012
 kworker/1:4-374     [001] ....   266.866671: rtcpu_vinotify_event: tstamp:8855001554 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:35 vi_tstamp:283359138880 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.922666: rtcpu_vinotify_error: tstamp:8856019001 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:36 vi_tstamp:283392471488 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.922667: rtcpu_vinotify_event: tstamp:8856086411 cch:0 vi:1 tag:FE channel:0x00 frame:35 vi_tstamp:283391740704 data:0x0000002300000022
 kworker/1:4-374     [001] ....   266.922667: rtcpu_vinotify_event: tstamp:8856086659 cch:0 vi:1 tag:FS channel:0x00 frame:36 vi_tstamp:283392442624 data:0x0000002400000012
 kworker/1:4-374     [001] ....   266.922667: rtcpu_vinotify_event: tstamp:8856086947 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:36 vi_tstamp:283392471488 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.978674: rtcpu_vinotify_error: tstamp:8857060645 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:37 vi_tstamp:283425804128 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.978678: rtcpu_vinotify_event: tstamp:8857171765 cch:0 vi:1 tag:FE channel:0x00 frame:36 vi_tstamp:283425073344 data:0x0000002400000022
 kworker/1:4-374     [001] ....   266.978680: rtcpu_vinotify_event: tstamp:8857172044 cch:0 vi:1 tag:FS channel:0x00 frame:37 vi_tstamp:283425775232 data:0x0000002500000012
 kworker/1:4-374     [001] ....   266.978680: rtcpu_vinotify_event: tstamp:8857172287 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:37 vi_tstamp:283425804128 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.978681: rtcpu_vinotify_error: tstamp:8858102289 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:38 vi_tstamp:283459136736 data:0x0000000000000249
 kworker/1:4-374     [001] ....   266.978681: rtcpu_vinotify_event: tstamp:8858257110 cch:0 vi:1 tag:FE channel:0x00 frame:37 vi_tstamp:283458405952 data:0x0000002500000022
 kworker/1:4-374     [001] ....   266.978681: rtcpu_vinotify_event: tstamp:8858257357 cch:0 vi:1 tag:FS channel:0x00 frame:38 vi_tstamp:283459107840 data:0x0000002600000012
 kworker/1:4-374     [001] ....   266.978682: rtcpu_vinotify_event: tstamp:8858257639 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:38 vi_tstamp:283459136736 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.034671: rtcpu_vinotify_error: tstamp:8859144116 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:39 vi_tstamp:283492469344 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.034671: rtcpu_vinotify_event: tstamp:8859145221 cch:0 vi:1 tag:FE channel:0x00 frame:38 vi_tstamp:283491738560 data:0x0000002600000022
 kworker/1:4-374     [001] ....   267.034671: rtcpu_vinotify_event: tstamp:8859145500 cch:0 vi:1 tag:FS channel:0x00 frame:39 vi_tstamp:283492440448 data:0x0000002700000012
 kworker/1:4-374     [001] ....   267.034672: rtcpu_vinotify_event: tstamp:8859145744 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:39 vi_tstamp:283492469344 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.034672: rtcpu_vinotify_error: tstamp:8860185576 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:40 vi_tstamp:283525801952 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.034672: rtcpu_vinotify_event: tstamp:8860210196 cch:0 vi:1 tag:FE channel:0x00 frame:39 vi_tstamp:283525071168 data:0x0000002700000022
 kworker/1:4-374     [001] ....   267.034672: rtcpu_vinotify_event: tstamp:8860210444 cch:0 vi:1 tag:FS channel:0x00 frame:40 vi_tstamp:283525773088 data:0x0000002800000012
 kworker/1:4-374     [001] ....   267.034673: rtcpu_vinotify_event: tstamp:8860210725 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:40 vi_tstamp:283525801952 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.090669: rtcpu_vinotify_error: tstamp:8861227221 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:41 vi_tstamp:283559134592 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.090670: rtcpu_vinotify_event: tstamp:8861294518 cch:0 vi:1 tag:FE channel:0x00 frame:40 vi_tstamp:283558403808 data:0x0000002800000022
 kworker/1:4-374     [001] ....   267.090670: rtcpu_vinotify_event: tstamp:8861294804 cch:0 vi:1 tag:FS channel:0x00 frame:41 vi_tstamp:283559105696 data:0x0000002900000012
 kworker/1:4-374     [001] ....   267.090670: rtcpu_vinotify_event: tstamp:8861295049 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:41 vi_tstamp:283559134592 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.146675: rtcpu_vinotify_error: tstamp:8862268867 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:42 vi_tstamp:283592467200 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.146676: rtcpu_vinotify_event: tstamp:8862379802 cch:0 vi:1 tag:FE channel:0x00 frame:41 vi_tstamp:283591736384 data:0x0000002900000022
 kworker/1:4-374     [001] ....   267.146676: rtcpu_vinotify_event: tstamp:8862380047 cch:0 vi:1 tag:FS channel:0x00 frame:42 vi_tstamp:283592438304 data:0x0000002a00000012
 kworker/1:4-374     [001] ....   267.146676: rtcpu_vinotify_event: tstamp:8862380334 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:42 vi_tstamp:283592467200 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.146677: rtcpu_vinotify_error: tstamp:8863310509 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:43 vi_tstamp:283625799840 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.146677: rtcpu_vinotify_event: tstamp:8863465142 cch:0 vi:1 tag:FE channel:0x00 frame:42 vi_tstamp:283625069056 data:0x0000002a00000022
 kworker/1:4-374     [001] ....   267.146677: rtcpu_vinotify_event: tstamp:8863465422 cch:0 vi:1 tag:FS channel:0x00 frame:43 vi_tstamp:283625770944 data:0x0000002b00000012
 kworker/1:4-374     [001] ....   267.146677: rtcpu_vinotify_event: tstamp:8863465663 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:43 vi_tstamp:283625799840 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.202673: rtcpu_vinotify_error: tstamp:8864352154 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:44 vi_tstamp:283659132416 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.202674: rtcpu_vinotify_event: tstamp:8864550491 cch:0 vi:1 tag:FE channel:0x00 frame:43 vi_tstamp:283658401632 data:0x0000002b00000022
 kworker/1:4-374     [001] ....   267.202674: rtcpu_vinotify_event: tstamp:8864550737 cch:0 vi:1 tag:FS channel:0x00 frame:44 vi_tstamp:283659103520 data:0x0000002c00000012
 kworker/1:4-374     [001] ....   267.202674: rtcpu_vinotify_event: tstamp:8864551017 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:44 vi_tstamp:283659132416 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.202674: rtcpu_vinotify_event: tstamp:8865369959 cch:0 vi:1 tag:FE channel:0x00 frame:44 vi_tstamp:283691734272 data:0x0000002c00000022
 kworker/1:4-374     [001] ....   267.202675: rtcpu_vinotify_error: tstamp:8865393795 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:45 vi_tstamp:283692465056 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.258676: rtcpu_vinotify_event: tstamp:8865906856 cch:0 vi:1 tag:FS channel:0x00 frame:45 vi_tstamp:283692436192 data:0x0000002d00000012
 kworker/1:4-374     [001] ....   267.258680: rtcpu_vinotify_event: tstamp:8865907104 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:45 vi_tstamp:283692465056 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.258681: rtcpu_vinotify_error: tstamp:8866435460 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:46 vi_tstamp:283725797696 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.258682: rtcpu_vinotify_event: tstamp:8866449570 cch:0 vi:1 tag:FE channel:0x00 frame:45 vi_tstamp:283725066912 data:0x0000002d00000022
 kworker/1:4-374     [001] ....   267.258682: rtcpu_vinotify_event: tstamp:8866449815 cch:0 vi:1 tag:FS channel:0x00 frame:46 vi_tstamp:283725768768 data:0x0000002e00000012
 kworker/1:4-374     [001] ....   267.258682: rtcpu_vinotify_event: tstamp:8866450099 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:46 vi_tstamp:283725797696 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.314673: rtcpu_vinotify_error: tstamp:8867477088 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:47 vi_tstamp:283759130304 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.314674: rtcpu_vinotify_event: tstamp:8867533832 cch:0 vi:1 tag:FE channel:0x00 frame:46 vi_tstamp:283758399520 data:0x0000002e00000022
 kworker/1:4-374     [001] ....   267.314674: rtcpu_vinotify_event: tstamp:8867534115 cch:0 vi:1 tag:FS channel:0x00 frame:47 vi_tstamp:283759101408 data:0x0000002f00000012
 kworker/1:4-374     [001] ....   267.314675: rtcpu_vinotify_event: tstamp:8867534360 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:47 vi_tstamp:283759130304 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.314675: rtcpu_vinotify_error: tstamp:8868518731 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:48 vi_tstamp:283792462912 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.314675: rtcpu_vinotify_event: tstamp:8868619204 cch:0 vi:1 tag:FE channel:0x00 frame:47 vi_tstamp:283791732128 data:0x0000002f00000022
 kworker/1:4-374     [001] ....   267.314675: rtcpu_vinotify_event: tstamp:8868619452 cch:0 vi:1 tag:FS channel:0x00 frame:48 vi_tstamp:283792434048 data:0x0000003000000012
 kworker/1:4-374     [001] ....   267.314676: rtcpu_vinotify_event: tstamp:8868619741 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:48 vi_tstamp:283792462912 data:0x0000000000000249
    v4l2-ctl-2814    [001] ....   267.334872: tegra_channel_close: vi-output, imx678 1-0010
    v4l2-ctl-2814    [001] ....   267.335079: tegra_channel_set_stream: enable : 0x0
    v4l2-ctl-2814    [001] ....   267.335081: tegra_channel_set_stream: imx678 1-0010 : 0x0
    v4l2-ctl-2814    [001] ....   267.340856: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x0
    v4l2-ctl-2814    [001] ....   267.340860: csi_s_stream: enable : 0x0
    v4l2-ctl-2814    [002] ....   267.345463: tegra_channel_set_power: imx678 1-0010 : 0x0
    v4l2-ctl-2814    [002] ....   267.345475: camera_common_s_power: status : 0x0
    v4l2-ctl-2814    [002] ....   267.354427: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x0
    v4l2-ctl-2814    [002] ....   267.354430: csi_s_power: enable : 0x0
 kworker/1:4-374     [001] ....   267.370683: rtcpu_vinotify_error: tstamp:8869560379 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:49 vi_tstamp:283825795520 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.370685: rtcpu_vinotify_event: tstamp:8869704551 cch:0 vi:1 tag:FE channel:0x00 frame:48 vi_tstamp:283825064736 data:0x0000003000000022
 kworker/1:4-374     [001] ....   267.370685: rtcpu_vinotify_event: tstamp:8869704829 cch:0 vi:1 tag:FS channel:0x00 frame:49 vi_tstamp:283825766624 data:0x0000003100000012
 kworker/1:4-374     [001] ....   267.370686: rtcpu_vinotify_event: tstamp:8869705071 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:49 vi_tstamp:283825795520 data:0x0000000000000249
 kworker/1:4-374     [001] ....   267.370686: rtcpu_vinotify_event: tstamp:8870133576 cch:-1 vi:1 tag:FE channel:0x00 frame:49 vi_tstamp:283837494112 data:0x0000003100000022
 kworker/1:4-374     [001] ....   272.642739: rtcpu_string: tstamp:9034876878 id:0x04010000 str:"VM0 deactivating."
use v4l2-ctl after nvgst-lanch
dmesg log:
[ 45.761094] imx678 1-0010: probing v4l2 sensor at addr 0x10
[ 45.761206] imx678 1-0010: mclk name not present, assume sensor driven externally
[ 45.761209] imx678 1-0010: avdd, iovdd and/or dvdd reglrs. not present, assume sensor powered independently
[ 45.761313] imx678 1-0010: tegracam sensor driver:imx678_1_v2.0.6
[ 45.761382] tegra-camrtc-capture-vi tegra-capture-vi: subdev imx678 1-0010 bound
[ 45.762392] imx678 1-0010: sensor_power_on: power on
[ 45.772001] imx678 1-0010: sensor_open:
[ 45.869220] imx678 1-0010: detected imx678_1 sensor
[ 64.542921] imx678 1-0010: sensor_open:
[ 65.047316] imx678 1-0010: sensor_set_gain:val:901 , gain: 3
[ 65.048226] imx678 1-0010: sensor_set_exposure_shr:coarse_time is 2024,val is 29999, shs0 is 226, factor is 1000000 !!!1
[ 65.049550] imx678 1-0010: sensor_power_on: power on
[ 65.053190] bwmgr API not supported
[ 65.053504] imx678 1-0010: imx678 set mode in 0!!!
[ 65.258470] imx678 1-0010: sensor_set_gain:val:901 , gain: 3
[ 65.259303] imx678 1-0010: sensor_set_exposure_shr:coarse_time is 2024,val is 29999, shs0 is 226, factor is 1000000 !!!1
[ 65.260534] imx678 1-0010: sensor_start_streaming:
[ 65.264641] bwmgr API not supported
[ 65.410680] bwmgr API not supported
[ 65.542506] imx678 1-0010: sensor_set_gain:val:1201 , gain: 4
[ 65.642503] imx678 1-0010: sensor_set_gain:val:1501 , gain: 5
[ 65.775860] imx678 1-0010: sensor_set_gain:val:1801 , gain: 6
[ 65.875839] imx678 1-0010: sensor_set_gain:val:2101 , gain: 7
[ 65.975849] imx678 1-0010: sensor_set_gain:val:2401 , gain: 8
[ 66.075817] imx678 1-0010: sensor_set_gain:val:2701 , gain: 9
[ 66.175792] imx678 1-0010: sensor_set_gain:val:3001 , gain: 10
[ 66.309119] imx678 1-0010: sensor_set_gain:val:3301 , gain: 11
[ 66.442464] imx678 1-0010: sensor_set_gain:val:3601 , gain: 12
[ 66.575785] imx678 1-0010: sensor_set_gain:val:3901 , gain: 13
[ 66.709145] imx678 1-0010: sensor_set_gain:val:4501 , gain: 15
[ 71.741356] imx678 1-0010: sensor_stop_streaming:
[ 71.745926] bwmgr API not supported
[ 71.746378] imx678 1-0010: sensor_power_off: power off
[ 76.729284] bwmgr API not supported
[ 224.343035] imx678 1-0010: sensor_power_on: power on
[ 224.357527] bwmgr API not supported
[ 224.358237] imx678 1-0010: imx678 set mode in 0!!!
[ 224.564891] imx678 1-0010: sensor_set_gain:val:4501 , gain: 15
[ 224.565739] imx678 1-0010: sensor_set_exposure_shr:coarse_time is 2024,val is 29999, shs0 is 226, factor is 1000000 !!!1
[ 224.570702] imx678 1-0010: sensor_start_streaming:
[ 224.651684] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 1, flags: 0, err_data 64
[ 224.685024] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 2, flags: 0, err_data 64
[ 224.718333] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 3, flags: 0, err_data 64
[ 224.751663] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 4, flags: 0, err_data 64
[ 226.121431] imx678 1-0010: sensor_stop_streaming:
[ 226.125631] bwmgr API not supported
[ 226.126471] imx678 1-0010: sensor_power_off: power off
[ 265.431083] imx678 1-0010: sensor_power_on: power on
[ 265.441230] bwmgr API not supported
[ 265.441930] imx678 1-0010: imx678 set mode in 0!!!
[ 265.656221] imx678 1-0010: sensor_set_gain:val:4501 , gain: 15
[ 265.663113] imx678 1-0010: sensor_set_exposure_shr:coarse_time is 2024,val is 29999, shs0 is 226, factor is 1000000 !!!1
[ 265.675662] imx678 1-0010: sensor_start_streaming:
[ 265.761637] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 1, flags: 0, err_data 64
[ 265.794943] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 2, flags: 0, err_data 64
[ 265.828227] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 3, flags: 0, err_data 64
[ 265.861549] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 4, flags: 0, err_data 64
[ 267.335107] imx678 1-0010: sensor_stop_streaming:
[ 267.344160] bwmgr API not supported
[ 267.345490] imx678 1-0010: sensor_power_off: power off
Looks like the output width more than expected.
https://elinux.org/Jetson/l4t/Camera_BringUp#Steps_to_enable_more_debug_messages
Thank you for your reply.
But what I see here is
Type: Video Capture
[0]: ‘RG12’ (12-bit Bayer RGRG/GBGB)
Why (87f)is 2175.
It’s start form 0. (2176 = [0-2175])
But if modiy sensor driver report:
3856x 2177,
     kworker/1:1-3549    [001] ....  3521.533622: rtcpu_string: tstamp:110644529967 id:0x04010000 str:"VM0 deactivating."
        v4l2-ctl-3576    [001] ....  3522.030366: tegra_channel_open: vi-output, imx678 1-0010
        v4l2-ctl-3576    [001] ....  3522.049492: tegra_channel_set_power: imx678 1-0010 : 0x1
        v4l2-ctl-3576    [001] ....  3522.049508: camera_common_s_power: status : 0x1
        v4l2-ctl-3576    [001] ....  3522.054683: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-3576    [001] ....  3522.054686: csi_s_power: enable : 0x1
        v4l2-ctl-3576    [001] ....  3522.055325: tegra_channel_capture_setup: vnc_id 0 W 3856 H 2177 fmt c4
        v4l2-ctl-3576    [002] ....  3522.062260: tegra_channel_set_stream: enable : 0x1
        v4l2-ctl-3576    [002] ....  3522.066154: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-3576    [002] ....  3522.066157: csi_s_stream: enable : 0x1
        v4l2-ctl-3576    [002] ....  3522.066549: tegra_channel_set_stream: imx678 1-0010 : 0x1
     kworker/1:1-3549    [001] ....  3522.097605: rtcpu_string: tstamp:110661908615 id:0x04010000 str:"VM0 activating."
     kworker/1:1-3549    [001] ....  3522.097608: rtcpu_vinotify_event: tstamp:110662546754 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3541185545504 data:0x759e300010000000
     kworker/1:1-3549    [001] ....  3522.097608: rtcpu_vinotify_event: tstamp:110662547034 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3541185555296 data:0x0000000031000001
     kworker/1:1-3549    [001] ....  3522.097608: rtcpu_vinotify_event: tstamp:110662547316 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3541185646336 data:0x759e2d0010000000
     kworker/1:1-3549    [001] ....  3522.097608: rtcpu_vinotify_event: tstamp:110662547563 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3541185656224 data:0x0000000031000002
     kworker/1:1-3549    [001] ....  3522.377837: rtcpu_vinotify_event: tstamp:110670685058 cch:0 vi:1 tag:FS channel:0x00 frame:1 vi_tstamp:3541456625024 data:0x0000000100000012
     kworker/1:1-3549    [001] ....  3522.377839: rtcpu_vinotify_event: tstamp:110670685319 cch:0 vi:1 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:3541456625120 data:0x0000000800000000
     kworker/1:1-3549    [001] ....  3522.377839: rtcpu_vinotify_event: tstamp:110670685605 cch:0 vi:1 tag:CHANSEL_EMBED_SOF channel:0x23 frame:1 vi_tstamp:3541456653536 data:0x0000000000000004
     kworker/1:1-3549    [001] ....  3522.377840: rtcpu_vinotify_event: tstamp:110670685848 cch:0 vi:1 tag:CHANSEL_EMBED_EOF channel:0x23 frame:1 vi_tstamp:3541456662720 data:0x0000000000000008
     kworker/1:1-3549    [001] ....  3522.377840: rtcpu_vinotify_event: tstamp:110670686121 cch:0 vi:1 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:1 vi_tstamp:3541456663968 data:0x0000000000000000
     kworker/1:1-3549    [001] ....  3522.377841: rtcpu_vinotify_event: tstamp:110670686368 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:1 vi_tstamp:3541456689088 data:0x0000000003020001
     kworker/1:1-3549    [001] ....  3522.377841: rtcpu_vinotify_event: tstamp:110670686645 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:1 vi_tstamp:3541456668448 data:0x00000000000006e9
     kworker/1:1-3549    [001] ....  3522.377841: rtcpu_vinotify_event: tstamp:110670686886 cch:0 vi:1 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:3541456964736 data:0x0000000000000001
     kworker/1:1-3549    [001] ....  3522.377842: rtcpu_vinotify_event: tstamp:110670687161 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:1 vi_tstamp:3541456975552 data:0x0000000008020001
     kworker/1:1-3549    [001] ....  3522.377842: rtcpu_vinotify_event: tstamp:110671549849 cch:0 vi:1 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:3541489210240 data:0x0000000008800002
     kworker/1:1-3549    [001] ....  3522.377843: rtcpu_vinotify_event: tstamp:110671550163 cch:0 vi:1 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:3541489211392 data:0x0000000000000000
     kworker/1:1-3549    [001] ....  3522.377843: rtcpu_vinotify_event: tstamp:110671550412 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:1 vi_tstamp:3541489233792 data:0x0000000002020001
     kworker/1:1-3549    [001] ....  3522.442784: rtcpu_vinotify_event: tstamp:110672041495 cch:0 vi:1 tag:CHANSEL_FAULT channel:0x23 frame:1 vi_tstamp:3541489215904 data:0x0000000008810040
Thank you for your support, I keep going up the height after success!
