V4l2-ctl video test error on Jetson Xavier NX
We have developed a custom carrier board for Jetson Xavier NX and have used it to capture a 4lane mipi csi-2 video.
v4l2-ctl -d /dev/video0 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw --set-fmt-video=width=1920,height=1080,pixelformat=UYVY
I got error log as follows:
 kworker/1:1-809   [001] ....  1118.433133: rtcpu_nvcsi_intr: tstamp:35209566087 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
 kworker/1:1-809   [001] ....  1118.433135: rtcpu_nvcsi_intr: tstamp:35209566087 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
 kworker/1:1-809   [001] ....  1118.433136: rtcpu_nvcsi_intr: tstamp:35209566087 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000e00
 kworker/1:1-809   [001] ....  1118.433137: rtcpu_nvcsi_intr: tstamp:35209566087 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000600
 kworker/1:1-809   [001] ....  1118.433138: rtcpu_nvcsi_intr: tstamp:35209567042 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x1e000000
 kworker/1:1-809   [001] ....  1118.433139: rtcpu_nvcsi_intr: tstamp:35209567042 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
 kworker/1:1-809   [001] ....  1118.433140: rtcpu_nvcsi_intr: tstamp:35209567042 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001e44
 kworker/1:1-809   [001] ....  1118.433141: rtcpu_nvcsi_intr: tstamp:35209567042 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000600
 kworker/1:1-809   [001] ....  1118.433142: rtcpu_nvcsi_intr: tstamp:35209567985 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000044
 kworker/1:1-809   [001] ....  1118.433144: rtcpu_nvcsi_intr: tstamp:35209569882 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
 kworker/1:1-809   [001] ....  1118.433145: rtcpu_nvcsi_intr: tstamp:35209569882 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
 kworker/1:1-809   [001] ....  1118.433146: rtcpu_nvcsi_intr: tstamp:35209569882 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00001000
 kworker/1:1-809   [001] ....  1118.433147: rtcpu_nvcsi_intr: tstamp:35209569882 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000044
 kworker/1:1-809   [001] ....  1118.937559: rtcpu_nvcsi_intr: tstamp:35226206381 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
 kworker/1:1-809   [001] ....  1118.937559: rtcpu_nvcsi_intr: tstamp:35226206381 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000e00
 kworker/1:1-809   [001] ....  1118.937559: rtcpu_nvcsi_intr: tstamp:35226206381 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000600
 kworker/1:1-809   [001] ....  1118.937560: rtcpu_vinotify_event: tstamp:35226207858 tag:CHANSEL_NOMATCH channel:0x01 frame:30409 vi_tstamp:35225683327 data:0x000003c9
 kworker/1:1-809   [001] ....  1118.937561: rtcpu_nvcsi_intr: tstamp:35226209089 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
 kworker/1:1-809   [001] ....  1118.937561: rtcpu_nvcsi_intr: tstamp:35226209089 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
 kworker/1:1-809   [001] ....  1118.937562: rtcpu_nvcsi_intr: tstamp:35226209089 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000e00
 kworker/1:1-809   [001] ....  1118.937563: rtcpu_nvcsi_intr: tstamp:35226209089 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000600
 kworker/1:1-809   [001] ....  1118.937564: rtcpu_nvcsi_intr: tstamp:35226210022 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
The trace file is 23.8MB big.
Check the REG NVCSI_PHY_0_CILA_INTR_0_STATUS_CILA_0 from TRM it show intr_cil_data_lane_sot_mb_err0_a that means multibit error of start of transmit.
Hi ShaneCCC,
Could we know the error cause of HW mipi csi signal issue or SW issue?
It’s could be the MIPI signal not follow the MIPI spec.
