v4l2_ctrl_handler_init function is error at TX1 R28.2.
i use imx219 mipi sensor .
this code is below:
static int imx219_ctrls_init(struct imx219 *priv)
struct i2c_client *client = priv->i2c_client;
struct v4l2_ctrl *ctrl;
int num_ctrls;
int err;
int i;
dev_info(&client->dev, "%s++\n", __func__);
num_ctrls = ARRAY_SIZE(ctrl_config_list);
v4l2_ctrl_handler_init(&priv->ctrl_handler, num_ctrls);
for (i = 0; i < num_ctrls; i++) {
ctrl = v4l2_ctrl_new_custom(&priv->ctrl_handler,
&ctrl_config_list[i], NULL);
if (ctrl == NULL) {
dev_err(&client->dev, "Failed to init %s ctrl\n",
ctrl_config_list[i].name);
continue;
if (ctrl_config_list[i].type == V4L2_CTRL_TYPE_STRING &&
ctrl_config_list[i].flags & V4L2_CTRL_FLAG_READ_ONLY) {
ctrl->p_new.p_char = devm_kzalloc(&client->dev,
ctrl_config_list[i].max + 1, GFP_KERNEL);
if (!ctrl->p_new.p_char) {
"Failed to allocate otp data\n");
return -ENOMEM;
priv->ctrls[i] = ctrl;
priv->num_ctrls = num_ctrls;
priv->subdev->ctrl_handler = &priv->ctrl_handler;
if (priv->ctrl_handler.error) {
dev_err(&client->dev, "Error %d adding controls\n",
priv->ctrl_handler.error);
err = priv->ctrl_handler.error;
goto error;
err = v4l2_ctrl_handler_setup(&priv->ctrl_handler);
if (err) {
"Error %d setting default controls\n", err);
goto error;
dev_info(&client->dev, "%s++ OK\n", __func__);
return 0;
error:
v4l2_ctrl_handler_free(&priv->ctrl_handler);
return err;
How can I fix this?
