Hi Shane,
Thanks for this doc. Finally, we have made MMAP working.
Now, we are facing issues with USER_PTR method.
v4l2-ctl command: strace -yy -tt -T v4l2-ctl --set-fmt-video=width=1472,height=1080 --stream-user -d /dev/video2 --verbose
Below Is the issue (with strace) we are facing:
02:14:23.460531 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b492c8) = 0 <0.000044>
02:14:23.460734 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000035>
02:14:23.460893 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000033>
02:14:23.461090 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000036>
02:14:23.461271 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000054>
02:14:23.461525 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000053>
02:14:23.461791 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000053>
02:14:23.462266 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000061>
02:14:23.462661 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000057>
02:14:23.462937 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000048>
02:14:23.463210 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000050>
02:14:23.463452 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000151>
02:14:23.463775 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000058>
02:14:23.464026 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000050>
02:14:23.464287 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000049>
02:14:23.464591 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000055>
02:14:23.464848 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000059>
02:14:23.465097 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000040>
02:14:23.465309 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000038>
02:14:23.465541 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000036>
02:14:23.465776 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000039>
02:14:23.466032 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = 0 <0.000058>
02:14:23.466289 ioctl(3</dev/video2>, VIDIOC_QUERY_EXT_CTRL, 0x7fe1b493b0) = -1 EINVAL (Invalid argument) <0.000050>
02:14:23.466556 ioctl(3</dev/video2>, VIDIOC_G_FMT, {type=V4L2_BUF_TYPE_VIDEO_CAPTURE, fmt.pix={width=1472, height=1080, pixelformat=v4l2_fourcc(‘R’, ‘G’, ‘1’, ‘0’), field=V4L2_FIELD_NONE, bytesperline=2944, sizeimage=3179520, colorspace=V4L2_COLORSPACE_SRGB}}) = 0 <0.000050>
02:14:23.466838 write(1</dev/pts/0>, “VIDIOC_G_FMT: ok\n”, 17VIDIOC_G_FMT: ok
) = 17 <0.000116>
02:14:23.467140 ioctl(3</dev/video2>, VIDIOC_S_FMT, {type=V4L2_BUF_TYPE_VIDEO_CAPTURE, fmt.pix={width=1472, height=1080, pixelformat=v4l2_fourcc(‘R’, ‘G’, ‘1’, ‘0’), field=V4L2_FIELD_NONE, bytesperline=0, sizeimage=3179520, colorspace=V4L2_COLORSPACE_SRGB} => fmt.pix={width=1472, height=1080, pixelformat=v4l2_fourcc(‘R’, ‘G’, ‘1’, ‘0’), field=V4L2_FIELD_NONE, bytesperline=2944, sizeimage=3179520, colorspace=V4L2_COLORSPACE_SRGB}}) = 0 <0.000084>
02:14:23.467437 write(1</dev/pts/0>, “VIDIOC_S_FMT: ok\n”, 17VIDIOC_S_FMT: ok
) = 17 <0.000125>
02:14:23.467737 write(1</dev/pts/0>, “Format Video Capture:\n”, 22Format Video Capture:
) = 22 <0.000100>
02:14:23.468008 write(1</dev/pts/0>, “\tWidth/Height : 1472/1080\n”, 31 Width/Height : 1472/1080
) = 31 <0.000110>
02:14:23.468270 write(1</dev/pts/0>, “\tPixel Format : ‘RG10’\n”, 28 Pixel Format : ‘RG10’
) = 28 <0.000146>
02:14:23.468604 write(1</dev/pts/0>, “\tField : None\n”, 26 Field : None
) = 26 <0.000089>
02:14:23.468887 write(1</dev/pts/0>, “\tBytes per Line : 2944\n”, 26 Bytes per Line : 2944
) = 26 <0.000118>
02:14:23.469243 write(1</dev/pts/0>, “\tSize Image : 3179520\n”, 29 Size Image : 3179520
) = 29 <0.000124>
02:14:23.469565 write(1</dev/pts/0>, “\tColorspace : sRGB\n”, 26 Colorspace : sRGB
) = 26 <0.000084>
02:14:23.469853 write(1</dev/pts/0>, “\tTransfer Function : Default (ma”…, 44 Transfer Function : Default (maps to sRGB)
) = 44 <0.000157>
02:14:23.470206 write(1</dev/pts/0>, “\tYCbCr/HSV Encoding: Default (ma”…, 49 YCbCr/HSV Encoding: Default (maps to ITU-R 601)
) = 49 <0.000105>
02:14:23.470504 write(1</dev/pts/0>, “\tQuantization : Default (ma”…, 50 Quantization : Default (maps to Full Range)
) = 50 <0.000114>
02:14:23.470768 write(1</dev/pts/0>, “\tFlags : \n”, 22 Flags :
) = 22 <0.000094>
02:14:23.471016 fcntl(3</dev/video2>, F_GETFL) = 0x20002 (flags O_RDWR|O_LARGEFILE) <0.000056>
02:14:23.471209 ioctl(3</dev/video2>, VIDIOC_SUBSCRIBE_EVENT, 0x7fe1b444f0) = -1 EINVAL (Invalid argument) <0.000062>
02:14:23.471415 ioctl(3</dev/video2>, VIDIOC_G_INPUT, [0]) = 0 <0.000238>
02:14:23.471797 ioctl(3</dev/video2>, VIDIOC_ENUMINPUT, {index=0, name=“Camera 4”, type=V4L2_INPUT_TYPE_CAMERA}) = 0 <0.000104>
02:14:23.472085 ioctl(3</dev/video2>, VIDIOC_REQBUFS, {type=V4L2_BUF_TYPE_VIDEO_CAPTURE, memory=V4L2_MEMORY_USERPTR, count=4 => 4}) = 0 <0.000112>
02:14:23.472390 write(1</dev/pts/0>, “VIDIOC_REQBUFS: ok\n”, 19VIDIOC_REQBUFS: ok
) = 19 <0.000119>
02:14:23.472658 ioctl(3</dev/video2>, VIDIOC_QUERYBUF, {type=V4L2_BUF_TYPE_VIDEO_CAPTURE, index=0, memory=V4L2_MEMORY_USERPTR, m.userptr=NULL, length=3179520, bytesused=0, flags=V4L2_BUF_FLAG_TIMESTAMP_MONOTONIC, …}) = 0 <0.000081>
02:14:23.472915 write(1</dev/pts/0>, “VIDIOC_QUERYBUF: ok\n”, 20VIDIOC_QUERYBUF: ok
) = 20 <0.000089>
02:14:23.473175 mmap(NULL, 3182592, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f96ae3000 <0.000111>
02:14:23.473471 ioctl(3</dev/video2>, VIDIOC_QBUF, {type=V4L2_BUF_TYPE_VIDEO_CAPTURE, index=0}) = -1 EINVAL (Invalid argument) <0.000086>
02:14:23.473707 write(1</dev/pts/0>, “VIDIOC_QBUF: failed: Invalid arg”…, 38VIDIOC_QBUF: failed: Invalid argument
) = 38 <0.000101>
02:14:23.473991 close(3</dev/video2>) = 0 <0.001160>
02:14:23.475446 exit_group(-1) = ?
02:14:23.476022 +++ exited with 255 +++
