V4L2 Jetson camera
I am using e-CAM24_CUNX camera. I want to configure two of the settings. as mentioned below that are required to be retained even after Nano restart. Could someone please suggest how can we achieve this with V4L2 or using any other mechanism?
  1. Have to change the number of frames to be captured. The camera support team claims that it supports 120 FPS, however, I want to reduce this to 60 FPS
  2. I want to change some other parameters such as the sharpness of the image as well as brightness.
Please contact with Econ to support this issue. Thanks
Hi Karunakar,
Please write to “camerasolutions@e-consystems.com”, our camera experts will assist you.
