Currently I am using camera v4l2 multimedia api to open a usb camera interface. All I wanted to do is to create a opencv path to display the same content simultaneously on the opencv window using the same camera buffer file. When I tried to implement this I only get a black screen with no error or warning.
static int
stream_opencvFrame(context_t * ctx)
struct pollfd fds[1];
NvBufferTransformParams transParams;
memset(&transParams, 0, sizeof(transParams));
transParams.transform_flag = NVBUFFER_TRANSFORM_FILTER;
transParams.transform_filter = NvBufferTransform_Filter_Smart;
ctx->renderer->enableProfiling();
fds[0].fd = ctx->cam_fd;
fds[0].events = POLLIN;
while (poll(fds, 1, 500) > 0 && !quit)
if (fds[0].revents & POLLIN) {
struct v4l2_buffer v4l2_buf;
/* Dequeue a camera buff */
memset(&v4l2_buf, 0, sizeof(v4l2_buf));
v4l2_buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
if (ctx->capture_dmabuf)
v4l2_buf.memory = V4L2_MEMORY_DMABUF;
else
v4l2_buf.memory = V4L2_MEMORY_MMAP;
if (ioctl(ctx->cam_fd, VIDIOC_DQBUF, &v4l2_buf) < 0)
ERROR_RETURN("Failed to dequeue camera buff: %s (%d)",
strerror(errno), errno);
ctx->frame++;
/* Save the n-th frame to file */
if (ctx->frame == ctx->save_n_frame)
save_frame_to_file(ctx, &v4l2_buf);
Mat image = imread (ctx->cam_file, IMREAD_COLOR);
String windowName = "screen";
namedWindow(windowName);
imshow(windowName, image);
waitKey(0);
return 0;
Here is my Opencv method which I call before the start capture method. When I try to call this after the start capture method I get segmentation error.
The code which I used is available here
