Thanks JerryChang!
That worked!
I am writing a video with
nvgstcapture -m 2 -k 2 -w 10
Is there a chance to use autofocus to increase the quality ?
Recorded sample:
https://drive.google.com/file/d/0B86kh-1GJW29T3ItOG1CYnJZZm8/view?usp=sharing
is there a way to get the video captured with guvcview?
ed to query video capabilities: Inappropriate ioctl for device
libv4l2: error getting capabilities: Inappropriate ioctl for device
V4L2_CORE: ERROR opening V4L2 interface for /dev/v4l-subdev0
Failed to query video capabilities: Inappropriate ioctl for device
V4L2_CORE: ERROR opening V4L2 interface for /dev/v4l-subdev1
V4L2_CORE: Unable to find parent usb device.V4L2_CORE: (UVCIOC_CTRL_MAP) Error: Inappropriate ioctl for device
You can try follow below thread to use video loopback
Thank you for sharing the link.
I’ve separated the question into a separate thread [url]https://devtalk.nvidia.com/default/topic/1019504/jetson-tx2/how-to-create-loopback-device-for-nvcamerasrc-for-tx2-/[/url]
ShaneCCC:
finally it created /dev/video0 device with the method [partially working]
# aptitude install v4l2loopback-source module-assistant
# module-assistant auto-install v4l2loopback-source
Is there any chance to redirect signal from the onboard camera to the /video0 device for it can be used with ordinary internet browser as a camera?
finally I managed to get it that way with supplied by colleague .ko file:
insmod v4l2loopback.ko devices=10
root@tegra-ubuntu:/home/nvidia/v4l2loopback# ls /dev/video* -l
crw-rw----+ 1 root video 81, 2 Sep 6 19:31 /dev/video0
crw-rw----+ 1 root video 81, 3 Sep 6 20:51 /dev/video1
crw-rw----+ 1 root video 81, 4 Sep 6 20:51 /dev/video2
crw-rw----+ 1 root video 81, 5 Sep 6 20:51 /dev/video3
crw-rw----+ 1 root video 81, 6 Sep 6 20:51 /dev/video4
crw-rw----+ 1 root video 81, 7 Sep 6 20:51 /dev/video5
crw-rw----+ 1 root video 81, 8 Sep 6 20:51 /dev/video6
crw-rw----+ 1 root video 81, 9 Sep 6 20:51 /dev/video7
crw-rw----+ 1 root video 81, 10 Sep 6 20:51 /dev/video8
now the issue is to make the flow from the onboard camera to be present at one of the created virtual devices
Hi JerryChang
when I input v4l2 cmmand , prompt system can not support , how can I add v4l2-ctl moudles
v4l2-ctl -d /dev/video0 --stream-mmap --stream-count=1 --stream-to=test.raw
-bash: v4l2-ctl: command not found
B/R
I would use insmod + v4l2loopback. I do use it actually. It returned the only way I can work with v4l2.
Regards
v4l2kernel.tar.gz (254 KB)
You can try install the v4l-utils or get the source from below link to build it yourself.
thanka alot
how to make nvgstcapture back to normal from upside-down?
try the ro:2 for the rotate 180 degrees.
like that?
nvgstcapture -m 2 -k 2 -w 10 ro:2
it wont affect the rotation that way as it seems to me
Try below command.
nvgstcapture --orientation=2
thank you
nvgstcapture --orientation=0
did the trick
Hey ShaneCCC,
i try to run yolo dakrnet with the onboard cam of a jetson tx2 flashed with JetPack 3.2.
But it gives me the following video signal error:
VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV
Couldn't connect to webcam.
: Invalid argument
darknet: ./src/utils.c:253: error: Assertion `0' failed.
Aborted (core dumped)
Do you have an idea what to put behind the darknet command as proper video signal?
./darknet detector demo cfg/coco.data cfg/yolo.cfg yolo.weights <video file>
