Hello, my name is Matthew and I’m working on programming vision on the jetson tx1. When I try to run my vision code, get this error: OpenCV Error: Unspecified error (The function is not implemented. Rebuild the library with Windows, GTK+ 2.x or Carbon support. If you are on Ubuntu or Debian, install libgtk2.0-dev and pkg-config, then re-run cmake or configure script) in cvNamedWindow, file /home/nvidia/Downloads/opencv-3.3.0/modules/highgui/src/window.cpp
After messing around with it for sometime, I realized that the problem lies in the highgui library in opencv. It seems to run well without imshow and waitKey. If anyone knows how to fix this, please help
