Vague error cuda installer log
Hi everyone, i tried to install nvidia driver version 450.51.06 from cuda toolkit 11.0 update 3. when i tried to install it failed and here’s the cuda-installer.log.
[INFO]: Driver not installed.
[INFO]: Checking compiler version...
[INFO]: gcc location: /usr/bin/gcc
[INFO]: gcc version: gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.2)
[INFO]: Initializing menu
[INFO]: Setup complete
[INFO]: Components to install:
[INFO]: Driver
[INFO]: 450.51.06
[INFO]: Executing NVIDIA-Linux-x86_64-450.51.06.run --ui=none --no-questions --accept-license --disable-nouveau --no-cc-version-check --install-libglvnd  2>&1
[INFO]: Finished with code: 256
[ERROR]: Install of driver component failed.
[ERROR]: Install of 450.51.06 failed, quitting
is code 256 mean something and how to fix it?
thanks,
argav
The cuda installer calls the driver installer
the driver installer failed, and it has its own log (which you should check).
I believe that driver installer log file name and location is listed later in the cuda installer log file that you have shown part of. It is usually at /var/log/nvidia-installer.log. It will generally have more details about what went wrong during the driver install.
