Hi nvidia,
i was testing different configuration on cuda before using one. It is confirmed from my program’s output that threads should be less than equal to 512 but there are some configurations which looks valid but are not working.
for example
Config: By=1, Bx=1, Ty=512, Tx=1 : Not Valid
Config: By=1, Bx=1, Ty=32, Tx=1 : Not Valid
Config: By=1, Bx=1, Ty=1, Tx=1 : Not Valid
Config: By=1, Bx=1, Ty=1, Tx=2 : Blocks=1 Threads=2 Valid
Config: By=1, Bx=1, Ty=1, Tx=4 : Blocks=1 Threads=4 Valid
Config: By=1, Bx=1, Ty=1, Tx=8 : Blocks=1 Threads=8 Valid
Config: By=1, Bx=1, Ty=1, Tx=16 : Blocks=1 Threads=16 Valid
Config: By=1, Bx=1, Ty=1, Tx=32 : Blocks=1 Threads=32 Valid
Config: By=1, Bx=1, Ty=1, Tx=64 : Blocks=1 Threads=64 Valid
Config: By=1, Bx=1, Ty=1, Tx=128 : Blocks=1 Threads=128 Valid
Config: By=1, Bx=1, Ty=1, Tx=256 : Blocks=1 Threads=256 Valid
Config: By=1, Bx=1, Ty=1, Tx=512 : Blocks=1 Threads=512 Valid
(where Tz = 1 in all cases)
Either my test program is giving incorrect results or there is any other technical reason for that. (my test program file is attached)
kindly help me with your comments.
thanks
configTest.txt (4.3 KB)
