Hello
ValueError occurred when start learning tlt-yolo.
Size of the training image is 1280 x 720.
The below error occurred when setting output_image_width, crop_right, output_image_height, and crop_bottom to the default values (1280, 720) and then starting learning.
However, I started learning by setting output_image_width, crop_right, output_image_height, and crop_bottom to the default values (960, 544), there is no error.
What is the reason for the error?
I wanna start training with 1280 x 720 training image.
Here is a train command and a full text of error :
tlt-train yolo -e yolo_start_train.txt -r /workspace/tlt/train_result_unpruned -k KEY -m /workspace/tlt/pretrained_model/darknet_53.hdf5
Using TensorFlow backend.
[[12734,1],0]: A high-performance Open MPI point-to-point messaging module
was unable to find any relevant network interfaces:
Module: OpenFabrics (openib)
Host: 1e257e6e231a
Another transport will be used instead, although this may result in
lower performance.
NOTE: You can disable this warning by setting the MCA parameter
btl_base_warn_component_unused to 0.
2020-07-06 07:44:33,725 [INFO] iva.yolo.scripts.train: Loading experiment spec at yolo_start_train.txt.
2020-07-06 07:44:33,726 [INFO] /usr/local/lib/python2.7/dist-packages/iva/yolo/utils/spec_loader.pyc: Merging specification from yolo_start_train.txt
target/truncation is not updated to match the crop areaif the dataset contains target/truncation.
File "/usr/local/bin/tlt-train-g1", line 8, in <module>
sys.exit(main())
File "./common/magnet_train.py", line 43, in main
File "./yolo/scripts/train.py", line 237, in main
File "./yolo/scripts/train.py", line 101, in run_experiment
File "./yolo/builders/model_builder.py", line 84, in build
File "./yolo/architecture/yolo_arch.py", line 211, in YOLO
File "./yolo/architecture/yolo_arch.py", line 91, in YOLO_FCN
File "/usr/local/lib/python2.7/dist-packages/keras/engine/base_layer.py", line 431, in __call__
self.build(unpack_singleton(input_shapes))
File "/usr/local/lib/python2.7/dist-packages/keras/layers/merge.py", line 362, in build
'Got inputs shapes: %s' % (input_shape))
ValueError: A `Concatenate` layer requires inputs with matching shapes except for the concat axis. Got inputs shapes: [(4, 256, 46, 80), (4, 512, 45, 80)]
