HI,When I use the convert-to-uff command to convert my own yolo_coco.pb file,The following happens
UFF Version 0.5.5
=== Automatically deduced input nodes ===
[name: “input/input_data”
op: “Placeholder”
attr {
key: “dtype”
value {
type: DT_FLOAT
attr {
key: “shape”
value {
shape {
unknown_rank: true
Using output node pred_sbbox/concat_2
Using output node pred_mbbox/concat_2
Using output node pred_lbbox/concat_2
Converting to UFF graph
Warning: No conversion function registered for layer: LeakyRelu yet.
Converting conv_lobj_branch/LeakyRelu as custom op: LeakyRelu
W0806 15:08:26.255614 140675493959424 deprecation_wrapper.py:119] From /usr/local/lib/python3.5/dist-packages/uff/converters/tensorflow/converter.py:189: The name tf.AttrValue is deprecated. Please use tf.compat.v1.AttrValue instead.
Converting conv56/LeakyRelu as custom op: LeakyRelu
Converting conv55/LeakyRelu as custom op: LeakyRelu
Converting conv54/LeakyRelu as custom op: LeakyRelu
Converting conv53/LeakyRelu as custom op: LeakyRelu
Converting conv52/LeakyRelu as custom op: LeakyRelu
Converting darknet/conv43/LeakyRelu as custom op: LeakyRelu
Converting darknet/conv26/LeakyRelu as custom op: LeakyRelu
Converting darknet/conv9/LeakyRelu as custom op: LeakyRelu
Converting darknet/conv4/LeakyRelu as custom op: LeakyRelu
Converting darknet/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/conv0/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual0/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual0/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual1/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual1/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual2/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual2/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual3/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual3/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual4/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual4/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual5/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual5/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual6/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual6/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual7/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual7/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual8/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual8/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual9/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual9/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual10/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual10/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual11/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual11/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual12/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual12/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual13/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual13/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual14/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual14/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual15/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual15/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual16/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual16/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual17/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual17/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual18/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual18/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual19/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual19/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual20/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual20/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual21/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual21/conv1/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual22/conv2/LeakyRelu as custom op: LeakyRelu
Converting darknet/residual22/conv1/LeakyRelu as custom op: LeakyRelu
Warning: No conversion function registered for layer: Cast yet.
Converting pred_lbbox/Cast as custom op: Cast
Warning: No conversion function registered for layer: Tile yet.
Converting pred_lbbox/Tile_2 as custom op: Tile
File “pb-uff.py”, line 21, in
trt_graph = uff.from_tensorflow_frozen_model(filename, output_nodes)
File “/usr/local/lib/python3.5/dist-packages/uff/converters/tensorflow/conversion_helpers.py”, line 187, in from_tensorflow_frozen_model
return from_tensorflow(graphdef, output_nodes, preprocessor, **kwargs)
File “/usr/local/lib/python3.5/dist-packages/uff/converters/tensorflow/conversion_helpers.py”, line 157, in from_tensorflow
debug_mode=debug_mode)
File “/usr/local/lib/python3.5/dist-packages/uff/converters/tensorflow/converter.py”, line 94, in convert_tf2uff_graph
uff_graph, input_replacements, debug_mode=debug_mode)
File “/usr/local/lib/python3.5/dist-packages/uff/converters/tensorflow/converter.py”, line 79, in convert_tf2uff_node
op, name, tf_node, inputs, uff_graph, tf_nodes=tf_nodes, debug_mode=debug_mode)
File “/usr/local/lib/python3.5/dist-packages/uff/converters/tensorflow/converter.py”, line 47, in convert_layer
return cls.registry_[op](name, tf_node, inputs, uff_graph, **kwargs)
File “/usr/local/lib/python3.5/dist-packages/uff/converters/tensorflow/converter_functions.py”, line 413, in convert_strided_slice
raise ValueError(“new_axis_mask not supported”)
ValueError: new_axis_mask not supported
How should I solve this bug?Thanks
