Values of output variables (keys) at grid points
I am dealing with a problem wherein the difference between solutions at ends of 1D domain is required as shown below.
self.equations[“Energy”] = T.diff(t) - I*(R_a**2/D_c)/(717*298) * (4.3 - (Phi_1.subs(x,13) - Phi_1.subs(x,0)))
I am hoping that “Phi_1.subs()” will evaluate “Phi_1” at the desired “x” location as is the case with sympy expressions.
When I print the equation using pprint() function, following expression is displayed.
-0.00412793799668642Phi_1 + 0.00412793799668642Phi_1 + T__t - 0.0177501333857516
Is the subs() function working here? This is not clear from the printed expression.
If it’s not working, is there a way around to achieve the same.
@ngeneva
Can you help me with this?
Hi @shubhamsp2195
I would imagine that as long as Phi_1 is a valid sympy expression, this should work fine although I don’t recall an example of us ever using this function.
To sanity check this you could take your custom PDE class, create the nodes using .make_nodes(), then manually check the evaluation of the equation via node.evaluate property to then feed in input variables manually. An example can be found here in the docs.
Thank you @ngeneva for this information
