Variable array size within kernel?
Hi guys,
I have a code that needs to do this
Data: a 3-dimensional data
data[x-coordinate, y-coordinate, energy]
for time
for x=0 to x_max
for y=0 to y_max
 a = [ x, y, *] // create an array/vector using every energy there is at this point
My plan is parallelize according to pixels
at time =0
create x_max*y_max number of threads to run the kernel below
the kernel ( int Emax)
float a[Emax];
for (e=0 to emax)
a[e] = data[tx,ty,e];
The compiler gives me an error because obviously I cant do float a[Emax]. Is there a way I can dynamically allocate memory?
Z
No replies?
Simply, can I create variable arrays within the CUDA kernel?
All dynamic memory allocation has to be initiated from the host-side. Global memory is allocated with cudaMalloc() and dynamic arrays in shared memory are controlled with a special parameter when you launch the kernel. (See the Programming Guide for more info on dynamic shared memory.)
Thanks seibert :)
