i would like to ask, what does the
“warning: Variable is not live at this point. Returning garbage value.” message means? I suppose that if i am debugging a kernel it has to be “live” at any point. Here i did few steps, the code doesn’t change the varriable “np” which is a pointer to a struct, but suddenly it changes when there is no code where it could possibly change. Why is this happening? (i’m using cuda 3.0 beta)
(cuda-gdb) step
[Current CUDA Thread <<<(0,0),(0,0,0)>>>]
nets_depth_propagate <<<gridDim=(1,1), blockDim=(1,12,1)>>> (level=1) at gpu.cu:115
115 me=(blockIdx.y*gridDim.x+blockIdx.x) * (blockDim.x*blockDim.y)+ threadIdx.y*blockDim.x + threadIdx.x;
(cuda-gdb) print *np
Cannot access memory at address 0x4000000000
(cuda-gdb) print me
$7 = 0
(cuda-gdb) step
nets_depth_propagate <<<gridDim=(1,1), blockDim=(1,12,1)>>> (level=1) at gpu.cu:116
116 if (me<np->inlinks[blockDim.x].num_entries) {
$8 = {nodes_total = 3221225471, links_total = 4261412863, nets_total = 4261330429, num_inputs = 63475,
num_outputs = 65535, min_weight = -1.99999988, links_max = 4294827901, nodes_max = 4294965229,
net_creation_result = 253 '�', deepest_level = 4290641918,
data_base_addr = 0xfff9df6b7f7dffff <Address 0xfff9df6b7f7dffff out of bounds>, data_len = 18428729674663165935,
lweights = 0xe7ff7fdffffcb5ff, srcs = 0xebdcffdfffffff7f, net_ids = 0xfffffffffffbdff3,
dsts = 0xfffef6ffffc7f7fe, nvalues = 0xdedde7fffeff2ffb, nmirror = 0xe7b5fffbfefdf5dd,
nfuncs = 0xdfffff7ffffeffbf <Address 0xdfffff7ffffeffbf out of bounds>, nets_table = 0xffffedff5f1fffdf,
inlinks = 0x7f7ffbff7ffffdff, depth_status = 0xffffee5f5cfdfdff <Address 0xffffee5f5cfdfdff out of bounds>,
depth_levels = 0xfbf6f7dfffdfefff, inputs = 0xffe7dfffffffffff, outputs = 0xfd77bbcfdfe87fff}
(cuda-gdb) print np
$9 = (@global net_pack_t * @register) 0xc0001
(cuda-gdb) step
nets_depth_propagate <<<gridDim=(1,1), blockDim=(1,12,1)>>> (level=1) at gpu.cu:117
117 srcs_base=np->inlinks[blockDim.x].srcnums_start_idx;
$10 = {nodes_total = 80, links_total = 60, nets_total = 4, num_inputs = 2, num_outputs = 1,
min_weight = 0.109999999, links_max = 2869360, nodes_max = 0, net_creation_result = 0 '
(cuda-gdb) step
115 me=(blockIdx.ygridDim.x+blockIdx.x) * (blockDim.xblockDim.y)+ threadIdx.y*blockDim.x + threadIdx.x;
(cuda-gdb) print me
$7 = 0
(cuda-gdb) step
116 if (meinlinks[blockDim.x].num_entries) {
net_creation_result = 253 ‘�’, deepest_level = 4290641918,
(cuda-gdb) print np
(cuda-gdb) step
min_weight = 0.109999999, links_max = 2869360, nodes_max = 0, net_creation_result = 0 ’
(cuda-gdb) step
(cuda-gdb) print me
$7 = 0
(cuda-gdb) step
(cuda-gdb) print np
(cuda-gdb) step
min_weight = 0.109999999, links_max = 2869360, nodes_max = 0, net_creation_result = 0 '\0', deepest_level = 0,
data_base_addr = 0xa12f88 <Address 0xa12f88 out of bounds>, data_len = 0, lweights = 0xa12f88, srcs = 0x1505148,
net_ids = 0x1a7e228, dsts = 0x1ff7308, nvalues = 0x25703e8, nmirror = 0x2688748, nfuncs = 0x27a0af0 "",
nets_table = 0x27a0aa8, inlinks = 0x27e1548, depth_status = 0x27e15f8 "weights2netjj", depth_levels = 0x27e4114,
inputs = 0x27eed84, outputs = 0x27eed8c}
(cuda-gdb)
net_ids = 0x1a7e228, dsts = 0x1ff7308, nvalues = 0x25703e8, nmirror = 0x2688748, nfuncs = 0x27a0af0 “”,
nets_table = 0x27a0aa8, inlinks = 0x27e1548, depth_status = 0x27e15f8 “weights2netjj”, depth_levels = 0x27e4114,
(cuda-gdb)
(cuda-gdb)
