variable sized arrays on device
In c/c++ one can easily create variable sized arrays using new/malloc - but here’s the problem I’m running into on cuda:
__global__ void k_matrix_multiply_multishared(Matrix d_A, Matrix d_B, Matrix d_C,
                                             int const tile_width) {
int sum = 0;
//create shared memory regions
    __shared__ float d_sA[tile_width][tile_width];    //<--- PROBLEM! tile_width is not known at compile time - throwing compiler errors
    __shared__ float d_sB[tile_width][tile_width];
int tx = threadIdx.x; int ty = threadIdx.y;
    int bx = blockIdx.x;  int by = blockIdx.y;
int row_id = by * tile_width + ty;
    int col_id = bx * tile_width + tx;
int tid = row_id * d_C.width + col_id;
//if d_C.width =4, and tile_width =2, it would need 2 phases!
    for(int i=0;i<d_C.width/tile_width;i++) {
float Pvalue = 0;
//load into shared memory
        //each thread loads their own part into the shared memory:
        d_sA[ty][tx] = d_A[row_id*d_A.width + (i*tile_width+tx)];
        d_sB[ty][tx] = d_B[col_id+d_B.width * (i*tile_width+ty)];
        __syncthreads();
for(int k=0;k<tile_width;k++) {
                Pvalue += d_sA[ty][k] * d_sB[k][tx];
__syncthreads();
d_C.data[tid] = Pvalue;
I don’t want to use #define to set tile_width, is there a way around this?
You can declare a shared memory array inside the kernel like this:
extern shared float sharedMemArray;
and then use cuFuncSetSharedSize (if using the driver API, otherwise there’s an equivalent in normal CUDA as well - see the programming guide) to set the array size you need when the kernel is loaded.
Hi - I wasn’t able to find the equivalent in normal CUDA - I just looked through the Cuda Programming Guide.
I call cuFuncSetSharedSize to allocate shared memory right before the kernel is launched?
I have another question
suppose:
in my kernel I have two external arrays that will occupy shared memory
extern shared d_sA;
extern shared d_sB;
before I invoke my kernel, I set
int shared_mem = sizeof(float) * length of array;
and do func<<<grid,block,shared_mem>>>func();
is shared_mem bytes of memory allocated individually for d_sA and d_sB?
No, both variables will share the same memory. Appendix B.2.3 of the Programming Guide demonstrates how to declare multiple dynamically allocated shared memory arrays.
No, shared_mem will be the total amount of shared memory allocated to your kernel. You can still declare two arrays inside your kernel but they will both point to the same place, so to access elements of the second one you would need to add to the index an offset equal to the size of the first array.
