Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
We are currently working with DRIVE OS 6.0.10.0, installed with the Docker container from NGC. We want to deploy different software components in their own, dedicated docker containers. Some of these components require CUDA-11.4 but some of them might require CUDA-12 to run. From past experience with Jetson Orin setups, it is possible to install various CUDA versions within the L4T container images, regardless of the underlying versions on the host machine OS. Can something similar be done on the DRIVE AGX Orin as well or is it maybe generally possible to make both CUDA versions (including different cuDNN versions) available on the DRIVE AGX Orin within the respective containers?
Basically is this scenario possible:
DRIVE AGX Orin - operating with CUDA 11-4
Docker Container 1 (running on the DRIVE AGX Orin) - operating with CUDA 11-4
Docker Container 2 (running on the DRIVE AGX Orin) - operating with CUDA 12
Error String
n/a
Logs
n/a
