Various Pin application questions when applying Jetson Orin NX to a carrier board
  1. Is there an issue with leaving the unused camera inputs floating (CSI#)?
  2. Is there an issue with leaving the unused USB inputs floating (USBSS#_RX)?
  3. Is there an issue with leaving the unused PCIe inputs floating (PCIE#_RX)?
  4. Do the reserved pins (RSVD) need any special treatment?
  5. How should the CAN bus be strapped if not used? Just a pull-down on the RX?
  6. How should the I2S signals be strapped if not used? Just a pull-down on the DIN pins?
Hi, all unused pins you list can be floating.
