Check this out, I can animate VBD density scale in create.
But when I import that USD to another master USD, the key values are not effective in curve editor / playback…
What can this be?
Pekka
What can this be?
Pekka
Hi Pekka, I was able to repro your issue locally. It’s something to do with the stage you’re dropping the vdb cloud payload into.
I was able to drop your main stage and cloud stage as separate payloads into a new stage and the animation worked there. This is your work-around for now.
