hi.
I have a question about the VBR behavior of the Jetson Nano H264 encoder.
When the rate control is set to VBR,
sometimes the stream is output at a bitrate about twice the target bitrate.
Is there an encoding parameter to fix this?
Gstreamer encoder property is shown below.
omxh264enc name=enc0 iframeinterval=60 bitrate=12000000 peak-bitrate=14400000 control-rate=1 vbv-size=10 EnableTwopassCBR=false EnableStringentBitrate=false insert-sps-pps=true profile=high insert-aud=true insert-vui=true cabac-entropy-coding=true
In the case of the above encoding parameters, a stream is sometimes output at 24 Mbps.
L4T uses version 32.2.0.
