Hi all, I am implementing a basic USB2.0 port on USB0 and will use it as USB Recovery…
The image above shows the VBUS_DETECT circuit, i cannot quite follow what its doing?
The Jetson Orin Nano product design guide says the VBUS needs to be level shifted…
It mentions “USB0_+/–”
But it seems the VBUS DETECT is simply connected to the high side of a mosfet which is turned on when VBUS goes high?
Am i right in saying that the arrangement of open drain GPIO on the orin, the mosfet and connection of VBUS to the gate of the mosfet is in itself a “Level shifter” …
This is all we need for VBUS detect?
Yes, it is for VBUS detect. And mosfet is a 5V to 1.8V level shift to 1.8V OD GPIO pin.
system
Closed
June 7, 2023, 12:53am
7
