I checked the net (buck output) “VDD_AV1V1_HUB” but its net doesn’t use any other schematics.
As a result of checking the “VDD_AV1V1_HUB” signal net, I checked that this signal net is not used.
What is the purpose of the schematic related to this net?
I’m asking if it is okay to delete the schematic related to this.
The VDD_AV1V1_HUB is the power supply for U7 (USB HUB), you can refer to the schematic diagram on page 20.
Of course, if you don’t use the USB HUB, you can remove this part of the circuit.
